Jendker
GPS Neo-6M with Raspbian Jessie
Sat Dec 05, 2015 3:20 pm
I have a problem, I was able to use GPS module on Raspbian Wheezy without any problems.
I am using this tutorial: https://github.com/mcauser/Raspberry-Pi ... GPS-NEO-6M but since Raspbian Jessy has changed to systemd i cannot use their description on how to disable serial port. I was trying to use raspi-config to disable the serial port, but while starting the gpsd command:
sudo gpsd -b -N -D 3 -n -F /var/run/gpsd.sock /dev/ttyAMA0 (which is the command to start the gpsd in the debug mode, normal command doesn't show any errors but doesn't start gpsd at all... I always used the debug to check GPS module on Wheezy)
The answer:
gpsd:INFO: launching (Version 3.11)
gpsd:ERROR: can't bind to IPv4 port gpsd, Address already in use
gpsd:ERROR: maybe gpsd is already running!
gpsd:ERROR: can't bind to IPv6 port gpsd, Address already in use
gpsd:INFO: command sockets creation failed, netlib errors -1, -1
Did anyone of you have more luck with running GPS Neo-6M on Raspbian Jessie?
punktea
Re: GPS Neo-6M with Raspbian Jessie
Sun Dec 06, 2015 3:10 pm
I have Neo-6M GPS device working fine with Jessie. I only needed to edit /boot/cmdline.txt (remove ttyAMA0) and reboot.
To run gpsd as daemon:
cat /etc/default/gpsd
START_DAEMON="true"
GPSD_OPTIONS=""
DEVICES="/dev/ttyAMA0"
USBAUTO="false"
GPSD_SOCKET="/var/run/gpsd.sock"
To run manually to debug:
/usr/sbin/gpsd -N -D 4 -F /var/run/gpsd.sock -P /var/run/gpsd.pid /dev/ttyAMA0
Jendker
Sun Dec 06, 2015 3:47 pm
Thank you punktea, setting the values in the /etc/default/gpsd solved the issue :)
Everything works fine.
terilars
Sat Jan 23, 2016 3:21 pm
I run an Adafruit GPS on Jessie. I have followed Adafruit tutorials and modified/etc/default/gpsd excactly like punktean said. In addition, I have edited /boot/cmdline.txt. I get exact same error message as OP from /usr/sbin/gpsd -N -D 4 -F /var/run/gpsd.sock -P /var/run/gpsd.pid /dev/ttyAMA0.
sudo killall gpsd and ps aux | grep ttyAMA0 gives:
pi 1298 0.0 0.1 4232 1832 pts/0 S+ 15:20 0:00 grep --color=auto ttyAMA0
Any ideas to further problem solving?
huseyinkoc
Sat Feb 06, 2016 12:41 pm
Why can not I get the latitude and longitude data.
Dingo_aus
Sun Mar 13, 2016 2:33 am
Jendker,
I think the issue you have is that Raspbian is not letting you open port 2947.
e.g. If you add -S 99 to your gpsd string does it change and open the port?
I suspect there is a default security setting blocking gpsd opening port 2947.
www.adventuresinsilicon.com
Dingo_aus
Sun Mar 13, 2016 2:58 am
Personally I have had much more success starting gpsd as a service than manually.
e.g. instead of gpsd -D8 -N ...
I run:
sudo service gpsd start
Then "cgps -s" gives me the right data.
rvn
Mon Apr 18, 2016 11:47 pm
i just had a hard time solving this problem, but then i found the solution in this thread from Per Linderholm: viewtopic.php?f=28&t=138711
Just change in
/lib/systemd/system/gpsd.socket
ListenStream=127.0.0.1:2947
to
ListenStream=0.0.0.0:2947
