jeremy_fritz
Camera robot and Power output concerns
Sat Nov 14, 2015 10:56 am
I am trying to build a "turnkey" Camera project, based on the GoPiGo kit: http://www.modmypi.com/raspberry-pi/set ... rch=gopigo
It's written that it's compatible with the Raspberry Pi A+ but my question is:
Has the Raspberry Pi A+ enough out power to feed: Thank you all!
BMS Doug
Re: Camera robot and Power output concerns
Mon Nov 16, 2015 9:24 am
jeremy_fritz wrote:Hi,
The A+ has the exact same power structure as the B+ but uses slightly less power itself.
If you can power it from a B+ you can power it from an A+.
The Servo might need to be powered from a separate source (whether you use an A+ or a B+) depending on it's power consumption..
Doug.
