RPi Crashes After WebIOPi Error
Posted: Thu Nov 12, 2015 5:32 pm
Hi;
I have an RPi Model B running WebIOPi to remote control a robot using a WiFi adaptor. The Pi is connected to an Arduino Nano via i2c, the Nano is used to drive the motors via an L298N H Bridge.
Every so often the controls become un-responsive and it appears the Pi has crashed? When this happens I cannot CTRL C out of the Python Program running in Terminal via SSH and I cannot log in via SSH using another terminal window. The video stream from the mounted Web Cam also freezes. The video stream is produced by MPEG-Streamer which is called from a script within the WebIOPi Python program.
Here is the output when it crashes:
Googling the error: IOError: [Errno 5] Input/output error brings up a suggestion that the error may be caused by read and write problems between the Nano and the RPi being too fast?
Exception happened during processing of request from ('192.168.1.68', 55607)
File "/usr/lib/python3.2/socketserver.py", line 295, in _handle_request_noblock
self.process_request(request, client_address)
File "/usr/lib/python3.2/socketserver.py", line 321, in process_request
self.finish_request(request, client_address)
File "/usr/lib/python3.2/socketserver.py", line 334, in finish_request
self.RequestHandlerClass(request, client_address, self)
File "/usr/lib/python3.2/socketserver.py", line 648, in __init__
self.handle()
File "/usr/lib/python3.2/http/server.py", line 396, in handle
self.handle_one_request()
File "/usr/lib/python3.2/http/server.py", line 384, in handle_one_request
method()
File "/usr/local/lib/python3.2/dist-packages/WebIOPi-0.7.1-py3.2-linux-armv6l.egg/webiopi/protocols/http.py", line 270, in do_POST
self.processRequest()
File "/usr/local/lib/python3.2/dist-packages/WebIOPi-0.7.1-py3.2-linux-armv6l.egg/webiopi/protocols/http.py", line 264, in processRequest
raise e
File "/usr/local/lib/python3.2/dist-packages/WebIOPi-0.7.1-py3.2-linux-armv6l.egg/webiopi/protocols/http.py", line 244, in processRequest
result = self.server.handler.do_POST(relativePath, self.rfile.read(length), compact)
File "/usr/local/lib/python3.2/dist-packages/WebIOPi-0.7.1-py3.2-linux-armv6l.egg/webiopi/protocols/rest.py", line 203, in do_POST
result = macro()
File "Hammerstein_2.0.py", line 39, in stop
writeNumber(number)
File "Hammerstein_2.0.py", line 28, in writeNumber
bus.write_byte(address, value)
Exception happened during processing of request from ('192.168.1.68', 55608)
self.handle()
method()
raise e
result = macro()
File "Hammerstein_2.0.py", line 51, in left
writeNumber(number)
Exception happened during processing of request from ('192.168.1.68', 55611)
self.handle()
method()
raise e
result = macro()
writeNumber(number)
Exception happened during processing of request from ('192.168.1.68', 55630)
self.handle()
method()
raise e
result = macro()
writeNumber(number)
----------------------------------------Googling the error: IOError: [Errno 5] Input/output error brings up a suggestion that the error may be caused by read and write problems between the Nano and the RPi being too fast?
