HashberryPee
periodic house ventilation
Mon Nov 09, 2015 12:42 pm
following circumstances:
My new house is under construction and I wanna supervise the humidity because it needs periodic ventilation.
So I'm looking for a simple solution to get those information on the screen in my office?
construction site: a Pi with a humidity sensor and an USB data stick.
at home: selfhosted owncloud instance (version 8.1.3)
My thought: write those information in a text file which will be synced to the owncloud. Is there a raspberry pi sync client? A commando line client at best.
Re: How to solve?
Mon Nov 09, 2015 2:16 pm
HashberryPee wrote:Hi,
Maybe WebIOPI & Weaved IoT could be a solution :?:
http://webiopi.trouch.com
https://www.weaved.com/raspberry-pi-remote-connection
fyi Raspbian Wheezy & Jessie have the OwnCloud Client in the Software Repository
Last edited by fruitoftheloom on Mon Nov 09, 2015 2:19 pm, edited 1 time in total.
RPi 4B 4GB (SSD Boot)..
fruit-uk
Re: periodic house ventilation
Have you looked at fhem? http://fhem.de
HashberryPee
Mon Nov 09, 2015 2:52 pm
Thanks for the comment.
Didn't fully get it yet but it looks interesting.
'...any TCP based service you want to make available remotely – securely and without port forwarding...'
Does it require a dedicated ip adress? (weaved)
HashberryPee
Mon Nov 09, 2015 2:57 pm
Note!
As far as I know it's not that easy or even possible to accomplish static ip adress over an USB data stick..
Laurens-wuyts
Mon Nov 09, 2015 3:08 pm
HashberryPee wrote:Does it require a dedicated ip adress? (weaved)
Weaved doesn't require a static IP. The raspberry pi is connect to your weaved account, in which you can login and the connect to the raspberry pi. ;)
Laurens
Mon Nov 09, 2015 3:14 pm
Laurens
+1
This also is beneficial as most 3G Dongle ISP's do not offer static IP etal....
Slackware
Sun Feb 14, 2016 1:22 pm
Why do you need the interface? I have 12 temp / humidity sensors in my attic, and just turn on the vent fans as needed for 5 minutes.
Inside house I have them in the secondary air ducts so I don't ship moist air from shower, or kitchen when balancing room temps. Server room lets the central heat off the hook a lot, and being able to pull cold air from downstairs helps with ac in summer.
