Page 2 of 2
Re: 240 v mains controller
Posted: Fri Nov 15, 2013 2:02 pm
by vectraboyv6
bump :)
Posted: Fri Nov 15, 2013 11:39 pm
by emgi
Hugh Jarse wrote:I have made some updates since I first posted the remote mains socket controller info.
The link now contains an update to the source code to work with the latest versions of the bcm2835 library, an example of using cron for automatic timed switching of sockets on/off, and update the circuit diagram, and a few corrections.
http://www.mhr.me.uk/projects/socketcontrol.html
Hi Hugh,
Your work fascinated me so much that I decided to write an alternative web interface for it.
The one I saw was pretty basic and I hope you haven't yet started work on improvements. :roll:
What I made today has a few features that make your system even more usable.
Additions:
1: Before accessing the switchboard you need to log in.
2: It is possible to use an alternate name for the sockets which can be updated via the website.
User data and socket names are stored in an embedded sqlite database.
The webserver I used is lighttpd which works out of the box with perl cgi.
Actual status of the ports is reflected in four variables; Socket01 - 04.
It is also really lightweight. The .tar file with all files from /var/www/ is just 61k.
http://cable-79-207.zeelandnet.nl/RCMS-Pi.tar
This is the very first version, not yet fully tested. Everything can be customized further if necessary.
/emgi
Posted: Fri Nov 15, 2013 11:46 pm
by Hugh Jarse
Hi stuart
to prevent the inversion you should set the line
#define k_Invert 1
to
#define k_Invert 0
and recompile.
Always best to confirm it is doing what you expect with a scope.
The compilation instructions are in the header and are basically
gcc -o sckctrl sckctrl.c -l bcm2835
Obviously this assumes that you have installed the bcm2835 library
regards
Hugh
Posted: Fri Nov 15, 2013 11:54 pm
by Hugh Jarse
emgi wrote: Hi Hugh,
Additions:
/emgi
Hi emgi
You are right that my user interface was very basic, I guess it was a proof of concept, but I am pleased to see that you are making some nice improvements. The idea of some form of security is an important one - this is also possible I using the web server itself to authenticate the user. Nice idea to add some presentation strings in a database so that if you redeploy the sockets to another room or another use, you dont have to hack the web page itself.
regards
Hugh
