Stephanie
Controlling a BeeWi SmartLite
Sun Aug 09, 2015 1:25 pm
I recently came across some "BeeWi SmartLite" bulbs at the local home-improvement shop. They are controlled through Bluetooth, and they can do white and RGB colours. The price was right so I picked up a couple and got to work trying to figure out how to control them with my Raspberry Pi.
The result is I've written a Python script that allows command-line control over the bulbs. They can be turned on and off, the brightness can be controlled, they can be set to colour or white mode, and the colour temperature of the white can be controlled.
I have also figured out how to set their internal timers and toggle their 'disco' mode but haven't bothered putting that in my script. For the timers, I have more faith in just setting cron jobs on the Pi to control things. Eg. come winter, I'm liking the thought of a light in my bedroom coming on when it's time for me to get up.
Finally, I've put in a status function to grab the bulb's current settings. It's mostly just for fun but can be useful in debugging.
Here's some examples of code output:
pi@mcpi ~ $ sudo beewibulb
Correct usage is "[sudo] beewibulb <device address> <command> [argument]"
       <device address> in the format XX:XX:XX:XX:XX:XX
       Commands:  toggle          - toggle light on / off
                  on              - turn light on
                  off             - turn light off
                  bright          - set brightness to 100%
                  medium          - set brightness to  60%
                  dim             - set brightness to  10%
                  colour RRGGBB   - set bulb to colour RRGGBB
                  white           - set bulb to white mode
                  warm            - set white to warm CCT
                  cool            - set white to cool CCT
pi@mcpi ~ $ sudo beewibulb D0:39:72:XX:XX:XX status
bulb name   = Zone 1 Bulb
firmware    = V2.2 R141224
raw status  = 01 b2 00 00 ff
bulbIsOn    = True
bulbIsWhite = True
brightness  = 100%
white tone  = cool
And here is the full Python script:
#!/usr/bin/env python2.7
#	A python script to control the BeeWi 'BBL207 - Smart LED Color Bulb'
#	BeeWi website: http://www.bee-wi.com/en.cfm
#	Tested & working with this bulb in particular: http://www.bee-wi.com/bbl207,us,4,BBL207-A1.cfm
#	by Stephanie Maks
#	Figured out with help from -- and thanks to -- the following sources:
#		http://stackoverflow.com/questions/24853597/ble-gatttool-cannot-connect-even-though-device-is-discoverable-with-hcitool-lesc
#		http://mike.saunby.net/2013/04/raspberry-pi-and-ti-cc2541-sensortag.html
#		https://github.com/sandeepmistry/node-yeelight-blue
#	note: this needs to be called with 'sudo' or by root in order to work with some of the hci commands
import os
import sys
import socket
from subprocess import call, check_output
import pexpect
import time
def cycleHCI() :
	# maybe a useless time waster but it makes sure our hci0 is starting fresh and clean
	# nope in fact we need to call this before each time we do hci or gatt stuff or it doesn't work
	call(['hciconfig', 'hci0', 'down'])
	time.sleep(0.1)
	call(['hciconfig', 'hci0', 'up'])
	time.sleep(0.1)
def getSettings(mac) :
	# read the settings characteristic (read handle is 0x0024)
	# command return value = 'Characteristic value/descriptor: 00 b2 ff 00 00'
	# function returns settings as array of five integers
	cycleHCI();
	settings_array = [0,0,0,0,0]
	raw_input=check_output(['gatttool', '-i', 'hci0', '-b', mac, '--char-read', '--handle=0x0024']);
	if ':' in raw_input:
		raw_list=raw_input.split(':')
		raw_data=raw_list[1]
		raw_data=raw_data.strip()
		octet_list=raw_data.split(' ')
		if len(octet_list) > 4 :
			for i in range(0, 5) :
				j = int(octet_list[i], 16)
				settings_array[i] = j
	return settings_array
def getDeviceInfo(mac) :
	deviceName = ''
	deviceVers = ''
	raw_input=check_output(['gatttool', '-i', 'hci0', '-b', mac, '--char-read', '--handle=0x0003']);
		for octet in octet_list :
			j = int(octet, 16)
			if j > 31 and j < 127 : deviceName += str(unichr(j))
	raw_input=check_output(['gatttool', '-i', 'hci0', '-b', mac, '--char-read', '--handle=0x0018']);
			j = int(octet, 16)
			if j > 31 and j < 127 : deviceVers += str(unichr(j))
	cycleHCI()
	return (deviceName, deviceVers)
def	writeCommandToBulb(mac, the_command) :
	# settings commands are sent to the 0x0021 characteristic
	# all commands are prefixed with 0x55 (85) and suffixed with 0x0d 0x0a (CR LF)
	if the_command != '' :
		the_command = '55' + the_command + '0D0A'
		cycleHCI()
		hd = check_output(['/usr/local/bin/hcitool', '-i', 'hci0', 'lecc', mac])
		ha = hd.split(' ');
		connectionHandle=0
		if ha[0] == 'Connection' and ha[1] == 'handle' : connectionHandle = ha[2]
		if connectionHandle > 0 :
			bulb = pexpect.spawn('gatttool -i hci0 -b ' + mac + ' -I')
			bulb.expect('\[LE\]>', timeout=60)
			bulb.sendline('connect')
			bulb.sendline('char-write-cmd 0x0021 ' + the_command)
			bulb.sendline('disconnect')
			bulb.sendline('exit')
			bulb.expect(pexpect.EOF, timeout=60)
			call(['hcitool', '-i', 'hci0', 'ledc', connectionHandle])
		cycleHCI()
def setBrightness(mac, value) :
	# brightness command is 12 [02 to 0B] (18, [2 to 11])
	if value == 'low' :
		writeCommandToBulb(mac, '1202')
	elif value == 'med' :
		writeCommandToBulb(mac, '1207')
	else :
		writeCommandToBulb(mac, '120B')
def setBulbWhiteTemp(mac, tone) :
	# brightness command is 11 [02 to 0B] (17, [2 to 11])
	if tone == 'warm' :
		writeCommandToBulb(mac, '110B')
	elif tone == 'cool' :
		writeCommandToBulb(mac, '1102')
def setBulbWhite(mac) :
	# set to white command is 14 FF FF FF (20, -128, -128, -128)
	writeCommandToBulb(mac, '14FFFFFF')
def setBulbColour(mac, colour) :
	# colour command is 13 RR GG BB (19, Red, Green, Blue)
	value = '13' + colour
	writeCommandToBulb(mac, value)
def switchBulbOn(mac) :
	# on command is 10 01 (16, 1)
	writeCommandToBulb(mac, '1001')
def switchBulbOff(mac) :
	# off command is 10 00 (16, 0)
	writeCommandToBulb(mac, '1000')
def printHelp() :
	print 'Correct usage is "[sudo] beewibulb <device address> <command> [argument]"'
	print '       <device address> in the format XX:XX:XX:XX:XX:XX'
	print '       Commands:  toggle          - toggle light on / off'
	print '                  on              - turn light on'
	print '                  off             - turn light off'
	print '                  bright          - set brightness to 100%'
	print '                  medium          - set brightness to  60%'
	print '                  dim             - set brightness to  10%'
	print '                  colour RRGGBB   - set bulb to colour RRGGBB'
	print '                  white           - set bulb to white mode'
	print '                  warm            - set white to warm CCT'
	print '                  cool            - set white to cool CCT'
if __name__=='__main__' :
	if os.geteuid() != 0 :
		print 'WARNING: This script may not work correctly without sudo / root. Sorry.'
	if len(sys.argv) < 3 :
		printHelp()
	else :
		bulbIsOn = False
		bulbIsWhite = False
		device_address = sys.argv[1]
		command = sys.argv[2]
		command = command.lower()
		extra = ''
		error = ''
		if len(sys.argv) == 4 : extra = sys.argv[3]
		extra = extra.lower()
		# address shortcuts
		if device_address == 'pp' : device_address = 'D0:39:72:XX:XX:XX'
		if device_address == 'z1' : device_address = 'D0:39:72:XX:XX:XX'
		if device_address == 'z4' : device_address = 'D0:39:72:XX:XX:XX'
		if len(device_address) != 17 :
			print 'ERROR: device address must be in the format NN:NN:NN:NN:NN:NN'
			exit()
		settings = getSettings(device_address)
		if (settings[0] % 2) == 1 : bulbIsOn = True
		if (settings[1] & 15) > 0 : bulbIsWhite = True
		if command == 'colour' and extra == 'ffffff' : command = 'white'
		if 'stat' in command :
			name, version = getDeviceInfo(device_address)
			status = '%02x %02x %02x %02x %02x' % (settings[0], settings[1], settings[2], settings[3], settings[4])
			colour = '%02x%02x%02x' % (settings[2], settings[3], settings[4])
			brightness = (((settings[1] & 240) >> 4) - 1) * 10
			print 'bulb name   = ' + name
			print 'firmware    = ' + version
			print 'raw status  = ' + status
			print 'bulbIsOn    = ' + str(bulbIsOn)
			print 'bulbIsWhite = ' + str(bulbIsWhite)
			print 'brightness  = ' + str(brightness) + '%'
			if bulbIsWhite :
				cct = (settings[1] & 15)
				if cct == 2 : cct = 'cool'
				if cct == 11 : cct = 'warm'
				print 'white tone  = ' + cct
			else :
				print 'colour      = ' + colour
		elif command == 'on' :
			if not bulbIsOn : switchBulbOn(device_address)
		elif command == 'off' :
			if bulbIsOn : switchBulbOff(device_address)
		elif command == 'toggle' :
			if bulbIsOn :
			else :
		elif bulbIsOn :
			if command == 'bright' :
				setBrightness(device_address, 'high')
			elif command == 'dim' :
				setBrightness(device_address, 'low')
			elif command == 'medium' :
				setBrightness(device_address, 'med')
			elif command == 'warm' or command == 'cool' :
				if bulbIsWhite : setBulbWhiteTemp(device_address, command)
			elif command == 'white' :
				if not bulbIsWhite : setBulbWhite(device_address)
			elif command == 'colour' :
				if len(extra) == 6 :
					setBulbColour(device_address, extra)
				elif extra == '' :
					extra = '%02x%02x%02x' % (settings[2], settings[3], settings[4])
				else :
					error = 'ERROR: colour command requires a 6-digit colour argument, in hex. eg. 6633CC'
			else :
				printHelp()
		else :
			error = 'off'
		if error != '' :
			if error == 'off' : error = 'ERROR: Turn the bulb on before trying to change the settings.'
			print error
	exit()
BeeWi have some other Bluetooth goodies (power outlet, temperature sensor) but I haven't seen them for sale. If I ever find them I'll try and incorporate them into the same or a similar script.
Cheers!
daviessm
Re: Controlling a BeeWi SmartLite
Thu Sep 03, 2015 4:51 pm
I'm looking to do something similar with their temperature sensor so I'm interested to know how you discovered how to control the light. Is there any public documentation?
degerrit
Fri Oct 23, 2015 11:08 am
Awesome job, Stephanie!
Also works with BeeWi light BBL125A1 on x86_64 which I'm using with DomotiGa.
Strange thing is though, the hcitool connect/disconnect [lecc/ledc] seems unnecessary on my system (openSUSE 13.1/x86_64) - in fact, the script doesn't work at all (fails silently) if I leave that in - looks like gatttool makes its own connection and doesn't use the handle provided by hcitool. Same for the cycleHCI() precaution you've made.
Here's a diff for my version. Since I don't have a Pi, yet, can't really say if these changes are for x86, for the BBL125A1, or for my version of BlueZ tools.
--- /usr/local/bin/beewibulb.orig       2015-10-23 12:54:29.603981000 +0200
+++ /usr/local/bin/beewibulb_GH_publish 2015-10-23 13:00:21.876615000 +0200
@@ -3,6 +3,7 @@
+#   Modified for BeeWi light BBL125A1 on openSUSE 13.1/x86_64 by Gerrit Hannaert, 23/10/2015
 #   by Stephanie Maks
@@ -10,9 +11,12 @@
+#      https://www.nowsecure.com/blog/2014/02/07/bluetooth-packet-capture-on-android-4-4/
+debug=0
 import os
 import sys
 import socket
@@ -75,24 +79,22 @@
-      cycleHCI()
-      hd = check_output(['/usr/local/bin/hcitool', '-i', 'hci0', 'lecc', mac])
-      ha = hd.split(' ');
-      connectionHandle=0
-      if ha[0] == 'Connection' and ha[1] == 'handle' : connectionHandle = ha[2]
-      if connectionHandle > 0 :
+      #cycleHCI()
+      if debug == 1 : print '(connect) gatttool -i hci0 -b ' + mac + ' -I'
+      # maybe also expect "Connection successful" ?
+      if debug == 1 : print '(command) char-write-cmd 0x0021 ' + the_command
+      if debug == 1 : print '(command) disconnect'
-         call(['hcitool', '-i', 'hci0', 'ledc', connectionHandle])
-      cycleHCI()
+      #cycleHCI()
degerrit
Sat Oct 24, 2015 11:50 am
daviessm wrote:I'm looking to do something similar with their temperature sensor so I'm interested to know how you discovered how to control the light. Is there any public documentation?
Hi there. I couldn't find any documentation, but what I did (before finding the issue I described below) is to trace/sniff/capture Bluetooth communication from the vendor's app. Was initially thinking of an adapter (Bluefruit LE Sniffer?) but I then worked with an old rooted Nexus 7 tablet and the Developer option to enable "Bluetooth HCI snoop" (copied the log file off using a File Manager app not adb). Easy & free! Just remember to write down when you pressed what button, so you can correlate the Bluetooth data to your actions.
See : https://www.nowsecure.com/blog/2014/02/ ... droid-4-4/
vekfra
Sat Mar 12, 2016 6:40 pm
Created a new post regarding the BeeWi Smart Temperature & Humidity Sensor BBW200-A1
viewtopic.php?f=37&t=139848
Was able to read the actual values :D
Ruler
Wed Apr 06, 2016 8:04 pm
I'm able to use your script, but the only thing that works is to get the status from the bulb via the status parameter at the end. When I try to set a value or toggle the bulb I get this error:
  File "bulbs.py", line 198, in <module>
  File "bulbs.py", line 128, in switchBulbOff
  File "bulbs.py", line 79, in writeCommandToBulb
  File "/usr/lib/python2.7/subprocess.py", line 566, in check_output
    process = Popen(stdout=PIPE, *popenargs, **kwargs)
  File "/usr/lib/python2.7/subprocess.py", line 710, in __init__
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1335, in _execute_child
    raise child_exception
OSError: [Errno 2] No such file or directory
And I don't know what file is meant and missing. Thanks for clearing my path ;)
Douglas6
Thu Apr 07, 2016 12:03 am
It could be hcitool. On my recent Jessie Raspbian, it's at '/usr/bin/hcitool', not '/usr/local/bin/hcitool'.
Dragafe
Fri Jul 29, 2016 11:19 pm
Hi ! I try to use this script, it work but juste if I want 'status' ... When I try to do other thing (like toggle or on/off) it doen't work. I don't know and I don't lean python again...
Please, help me !
Thank you.
houkun1230
Tue Aug 09, 2016 6:01 pm
Dragafe wrote:Hi ! I try to use this script, it work but juste if I want 'status' ... When I try to do other thing (like toggle or on/off) it doen't work. I don't know and I don't lean python again...
Please, help me !
Thank you.
I meet the same problem, have you solved it? Do you know how to solve it? Thank you
vulture_g7
Mon Jan 30, 2017 11:07 am
@Stephanie
Resurrecting the thread here, could you please post the additional commands for timers control and colour cycle modes?
Thx!
pbaglivo
Wed Jan 30, 2019 8:38 pm
Do i need just to run the script in order to control the light bulb ?
bytheway
Sun Mar 24, 2019 7:40 pm
Very helpful script thanks. It works with a newly bought bulb (BLR11 rev E27-AW11, March 2019). I had to make three edits and install an extra library. My notes:
0. Install python 2.7 on your Pi
1. Make sure extra libraries like "pexpect" are also installed (or you will get errors telling you what is missing)
2. Open this page in a web browser on the Pi, and use "select all" in the code above, copy, paste it into a new blank text document and save it as a new python script file as "beewibulb.py" in a directory on the Pi like "/home/pi/beewi"
3. I had top change "print 'white tone = ' + cct" to "print 'white tone = ' + str(cct)" and "print 'colour = ' + colour" to "print 'colour = ' + str(colour)" by adding the str() function
4. I had to change "/usr/local/bin/hcitool" to "/usr/bin/hcitool" as mentioned in other comments above
5. Save the modified script (and download a copy somewhere safe)
6. Plug your BeeWi bulb into the mains, and install/run the BeeWi "SmartPad" app on my mobile phone
7. Use the app to add a new device and make a note of its MAC address (like XX:XX:XX:XX:XX:XX)
8. On the Pi, open a command/terminal prompt and go to the directory you saved the script file in (e.g. cd /home/pi/beewi
9. Run the script like this but replacing XX:XX:XX:XX:XX:XX with the unique address you noted above:
"sudo python beewibulb.py XX:XX:XX:XX:XX:XX status" or "sudo python beewibulb.py XX:XX:XX:XX:XX:XX dim" etc.
