DS18B20 one wire temp sensor not being detectec
Posted: Mon Jul 20, 2015 11:34 am
by carterzrock
This was all using the Pi 2 B v1.1
I have connected the sensor as you can see below. I have included the pullup 4.7k resistor.
I have modded the boot/config file. Followed by a "sudo reboot". See bottom line.
(just noticed the overscan left ="" - i corrected that and it doesnt seem to be causing issues.)
But still the Pi is not sensing it.
Ive used a multimeter to check that
-the wires are connected. Legs of the sensor to the gpio pins are good.
-The 3.3v pin is 3.3v compared to the GND pin
-the 4.7k resistor is actually 4.7k
Ive tried three different identical sensors.
Ive tried adding ",gpiopin=4" to the end of the boot/config line.
All this was all completed after a "sudo apt-get update" followed by "sudo apt-get upgrade".
Still no joy
Any ideas?
Re: DS18B20 one wire temp sensor not being detectec
Posted: Mon Jul 20, 2015 12:37 pm
by RST8
if you:
sudo modprobe w1-gpio
sudo modprobe w1-therm
then look in /sys/bus/w1/devices
there should be an entry something along the lines of
/28-03146c6b24ff/w1_slave
the first part is a serial number, so will vary between your 3 sensors.
Joe
Posted: Mon Jul 20, 2015 1:09 pm
by danjperron
What kind of DS18B20 you have
DS18B20 or DS18B20P?
"P" means parasite mode.
If you have a DS18B20P the Power is on the DATA line. Your setup won't work!
Posted: Mon Jul 20, 2015 1:26 pm
by danjperron
Try on parasite mode.
DS18B20 pin 1 & 3 to ground.
Add pullup="y" in option to enable parasitic mode
Posted: Tue Jul 21, 2015 9:25 am
by carterzrock
danjperron wrote:Try on parasite mode.
Are you suggesting i add
dtoverlay=w1-gpio-pullup,gpiopin=4,pullup=y
To the boot/config file to enable parasite mode?
