frafrichile
Pig counter
Wed Jun 24, 2015 8:22 pm
Hi everyone . I started my new job at a pig factory.
I noticed the people look at the security cameras and count the pigs manually. ! boring !!
so I thought to myself.
What could I put together to count these pigs. Any ideas? any sensors ?
Thank you guys !
scotty101
Re: Pig counter
Thu Jun 25, 2015 12:24 pm
A revolving gate that only allows one pig through at once and a sensor like a microswitch to detect when the gate is opened and closed.
frafrichile
Re: Pig counter
Thu Jun 25, 2015 12:54 pm
scotty101 wrote:A revolving gate that only allows one pig through at once and a sensor like a microswitch to detect when the gate is opened and closed.
what type of microswitch are you thinking?
Also are you familiar with PIR sensors ??
ame
Re: Pig counter
Thu Jun 25, 2015 1:02 pm
Any microswitch will do.
PIR sensors are probably no good as they will not discriminate between a single pig and a group of pigs.
You could try OpenCV and see if you could train it to look for pig-shaped objects.
frafrichile
Re: Pig counter
Thu Jun 25, 2015 3:50 pm
OpenCV looks very promising but also a lot of work.
the gate/hall is usually pretty narrow allowing 1 or 2 to get through at a time.
Wonder how hard is to set up OpenCV or if it can be applied on a livestream feed
scotty101
Re: Pig counter
Thu Jun 25, 2015 3:53 pm
KISS - Keep it Simple Stupid.
Why create a complex image recognition system to detect pigs when a switch and simple counter program will do?
