evilkitty
7 segment displays
Tue Jun 23, 2015 11:26 am
I plan to use 2 two digit displays with a A+ board
When i was looking at this i saw one only using 4 pins not noticing the IC behind it
it seems it is still possible to use without that, but it needs a LOT of GPIO pins
currently i have 6 in use (board pins 1,2,7,9,11, and 12)
i plan to use another 4 pins for digital logic via a switch
that would total 6 of my logic pins in use before the displays
* Pin 7 (aka GPIO 4 is my DS18B20 sensor)
do i have enough pins to control the 2 panels directly?
* common anode
My Pi Server: http://imgur.com/a/6xIUI | Thermostat: http://imgur.com/a/4LVnT
ame
Re: 7 segment displays
Tue Jun 23, 2015 11:33 am
The classic way to drive a bunch of 7-segment displays is one line per segment, plus one line per digit. So in your case that's 12 ( don't forget the decimal point).
If that's too many then you can start using shift registers, demultiplexers, and other tricks.
Driving your display from the Pi is no different to using a Z80, 6502, PIC, Arduino, whatever. Find a solution that appeals to you and fits within the restrictions you have.
evilkitty
Tue Jun 23, 2015 11:46 am
i will not be needing the decimal point for temp readouts ;)
evilkitty
Tue Jun 23, 2015 11:58 am
ame wrote:The classic way to drive a bunch of 7-segment displays is one line per segment, plus one line per digit. So in your case that's 12 ( don't forget the decimal point).
but 1 per segment + 1 per digit != 12
7 segment * 4 + 4 = 32 or 36 with the decimal
where did 12 come from?
Douglas6
Tue Jun 23, 2015 12:23 pm
7 + 1 segments + 4 digits = 12. The digits are multiplexed, and share the segment lines. But the I2C backpacks are so much easier.
ame
Tue Jun 23, 2015 12:46 pm
evilkitty wrote: but 1 per segment + 1 per digit != 12
How many segments? 8 (including d.p.)
How many digits? 4
8+4=12
As I said, people have been doing this for decades, so there are many techniques for saving pins.
DavidMS
Tue Jun 23, 2015 1:02 pm
You can have a look at http://www.pimuxclock.co.uk for how it can work in practice, if you look on the download page you can see some example code for a 4 digit display
http://meanderingpi.wordpress.com/
11 Raspberry Pi's and counting....
evilkitty
Tue Jun 23, 2015 7:32 pm
im planning to use 2 separate two digit displays, i will not be needing decimal points
though i guess i could use a button to switch the readout and use 1 display
i am not familiar with 7segment led stuff or using any of the tricks to increase GPIO pins
asandford
Tue Jun 23, 2015 7:40 pm
evilkitty wrote:im planning to use 2 separate two digit displays, i will not be needing decimal points
Use a spi device with max7219 controller, dirt cheap on ebay
evilkitty
Tue Jun 23, 2015 8:58 pm
that looks a little too big, i only have 65mm to work with and i need to stick a mini toggle switch in the middle of that
though if i solder stuff on to a 2x8cm board i can put that out of the way
asandford
Wed Jun 24, 2015 7:00 pm
evilkitty wrote:that looks a little too big, i only have 65mm to work with and i need to stick a mini toggle switch in the middle of that
The max7219 can control up to 8, 7 seg displays (plus DP), but can also work with 4. The chips are available in DIL packages, so are quite 'hobby' friendly (no smd soldering required), and are easy to wire up on proto- or breadboards.
evilkitty
Fri Jun 26, 2015 1:25 am
thanks, would using a chip like that take the looping load off of the pi or would i still be changing output every few hundred nanoseconds to display multiple digits?
i figured out how the 7segment actually work :)
since i am going to be suing common anode panels, i guess i should use a PNP transistor as a switch for each digit
if i were going to drive the panel from the pi
i would put a GPIO to each of the 7 segments (not using decimal point)
then put a GPIO to each PNP transistor
have + 3.3 to the PNP collectors, while the emitter goes to the panel's voltage input
what would be a decent choice PNP transistor (one good for fast switching at low voltages)
(one that can be soldered to 2.54mm breadboard)
asandford
Sat Jun 27, 2015 11:02 pm
evilkitty wrote:thanks, would using a chip like that take the looping load off of the pi or would i still be changing output every few hundred nanoseconds to display multiple digits?
With the MAX chip you set registers corresponding to the dispaly number values, not the individual segments (it has and inbuilt 'font' so if you set 0, it displays "0" ). It handles all the multiplexing, you only need to send updates over spi when the values change.
evilkitty
Sun Jun 28, 2015 10:43 am
a quick look on ebay shows it being sold with common cathode displays, does it work with common anode?
if not is there a version for common anode?
does it have resistors and transistors built in so it can be directly connected to the LEDs?
ame
Sun Jun 28, 2015 11:14 am
evilkitty wrote:a quick look on ebay shows it being sold with common cathode displays, does it work with common anode?
A quick Google will obtain for you the driver chip data sheet. The data sheet will answer all of your questions and more.
evilkitty
Sun Jun 28, 2015 3:06 pm
it does not support common node
but you do some clever tricks to make it work
http://marco-difeo.de/2013/02/21/drive- ... -displays/
is there a version of this chip for common anode?
