php, python, cgi, apache
Posted: Sat Apr 11, 2015 7:16 am
by frafrichile
Hello everyone
I followed this tutorial http://www.raspberrypi-spy.co.uk/2013/1 ... n-mcp3008/
I got it working thank god, took me a while but finally came through.
my question now is .I have a server set up on the raspberry pi. How can I make the data that I get from running the python script to be visible on my webserver.
This is the code I am working with
#!/usr/bin/python
import spidev
import time
import os
# Open SPI bus
spi = spidev.SpiDev()
spi.open(0,0)
# Function to read SPI data from MCP3008 chip
# Channel must be an integer 0-7
def ReadChannel(channel):
  adc = spi.xfer2([1,(8+channel)<<4,0])
  data = ((adc[1]&3) << 8) + adc[2]
  return data
# Function to convert data to voltage level,
# rounded to specified number of decimal places.
def ConvertVolts(data,places):
  volts = (data * 3.3) / float(1023)
  volts = round(volts,places)
  return volts
# Function to calculate temperature from
# TMP36 data, rounded to specified
# number of decimal places.
def ConvertTemp(data,places):
  # ADC Value
  # (approx)  Temp  Volts
  #    0      -50    0.00
  #   78      -25    0.25
  #  155        0    0.50
  #  233       25    0.75
  #  310       50    1.00
  #  465      100    1.50
  #  775      200    2.50
  # 1023      280    3.30
  temp = ((data * 330)/float(1023))-50
  temp = round(temp,places)
  return temp
# Define sensor channels
light_channel = 0
temp_channel  = 1
# Define delay between readings
delay = 5
while True:
  # Read the light sensor data
  light_level = ReadChannel(light_channel)
  light_volts = ConvertVolts(light_level,2)
  # Read the temperature sensor data
  temp_level = ReadChannel(temp_channel)
  temp_volts = ConvertVolts(temp_level,2)
  temp       = ConvertTemp(temp_level,2)
  # Print out results
  print "--------------------------------------------"
  print("Light: {} ({}V)".format(light_level,light_volts))
  print("Temp : {} ({}V) {} deg C".format(temp_level,temp_volts,temp))
  # Wait before repeating loop
  time.sleep(delay)
Thanks again
Re: php, python
Posted: Sat Apr 11, 2015 7:26 am
by Laurens-wuyts
For displaying python data on a webpage, you can use cgi. ;)
Laurens
Re: php, python
Posted: Tue Apr 21, 2015 12:42 am
by frafrichile
I got cgi working on an apache server. But how do I embed the script or what do I need to do??
Thanks!
Re: php, python
Posted: Wed Apr 22, 2015 10:34 am
by Laurens-wuyts
Just use the script and use print to display the code. ;)
Laurens
Re: php, python
Posted: Wed Apr 22, 2015 3:53 pm
by WebPi
You need to save the script in /usr/lib/cgi-bin and make sure it has executable permissions.
Next, add some code near the start of your script to print HTTP headers:
print "Content-type: text/html\n\n"
Add HTML formatting to the output:
print "<bold>Light:</bold>"
Here's a crash course in CGI scripting: http://raspberrywebserver.com/cgiscripting/
Re: php, python, cgi, apache
Posted: Thu Apr 23, 2015 3:20 am
by frafrichile
I will give it a try.
Thank you
My next question is how can I make this data go on a google sheet? I want to be able to graph it. and be able to see it on my server.
Posted: Thu Apr 23, 2015 12:30 pm
by WebPi
You could try following this tutorial about Google Docs: https://learn.adafruit.com/dht-humidity ... cs-updated
Alternatively, you could store the data in an SQLite database: http://raspberrywebserver.com/sql-databases/
Posted: Tue Apr 28, 2015 12:28 am
by frafrichile
Thank you guys. you are all very helpul
I put the python script mcp3008.py in this folder /usr/lib/cgi-bin . now the file is there but do I go to
http://192.168.2.100/cgi-bin/mcp3008.py ???????
and if so all I get is
Light:
Does the python script mcp3008.py have to be running or somehow cgi calls the script?
Posted: Tue Apr 28, 2015 12:46 am
by WebPi
Apache will call the script, so you don't need to start it in advance. It looks like you're using the correct URL. Make sure the script is executable. Also, double check that you added the AddHandler directive to /etc/apache2/sites-enabled/000-default (see http://raspberrywebserver.com/cgiscript ... ython.html).
Posted: Tue Apr 28, 2015 4:14 pm
by frafrichile
hmm
I did all the above, yet still I don't see the data.
All I see is
Light:
Posted: Tue Apr 28, 2015 4:19 pm
by WebPi
Are there any error messages in /var/log/apache2/error.log?
Posted: Thu Apr 30, 2015 2:18 am
by frafrichile
WebPi wrote:Are there any error messages in /var/log/apache2/error.log?
This is what I see
[Wed Apr 29 21:15:37 2015] [error] [client 192.168.2.1] Traceback (most recent call last):
[Wed Apr 29 21:15:37 2015] [error] [client 192.168.2.1]   File "/usr/lib/cgi-bin/mcp3008.py", line 21, in <module>
[Wed Apr 29 21:15:37 2015] [error] [client 192.168.2.1] spi.open(0,0)
[Wed Apr 29 21:15:37 2015] [error] [client 192.168.2.1] IOError: [Errno 13] Permission denied
[Wed Apr 29 21:15:38 2015] [error] [client 192.168.2.1] File does not exist: /var/www/favicon.ico, referer: http://192.168.2$
This is my currrent code, so far
#!/usr/bin/env python
# This script reads data from a
# MCP3008 ADC device using the SPI bus.
# Author : Matt Hawkins
# Date   : 13/10/2013
# http://www.raspberrypi-spy.co.uk/
import spidev
import time
import os
# Open SPI bus
spi.open(0,0)
  return data
  return volts
  # ADC Value
  #    0      -50    0.00
  #   78      -25    0.25
  #  155        0    0.50
  #  233       25    0.75
  #  310       50    1.00
  #  388       75    1.25
  #  465      100    1.50
  #  543      125    1.75
  #  620      150    2.00
  #  698      175    2.25
  #  775      200    2.50
  #  853      225    2.75
  #  930      250    3.00
  # 1008      275    3.25
  # 1023      280    3.30
  return temp
light_channel = 0
temp_channel  = 1
delay = 5
while True:
  # Print out results
  print "------The 'Ponics Project--------------------------------------"
  print("Light : {} ({}V)".format(light_level,light_volts))
  print("Temperature in the room  is: {} ({}V) {} deg F".format(temp_level,temp_volts,(temp * 9/5)+ 32))
  time.sleep(delay)
Thanks !
Posted: Sat May 02, 2015 4:24 pm
by WebPi
This is a problem with the permission of the SPI interface. I think it's owned by root, but your script is running as Apache's user name, www-data. You need to give www-data access to SPI.
According to this thread, you need to add www-data to the spi group: viewtopic.php?f=28&t=106814
This is the command you need to use:
sudo adduser www-data spi
Posted: Sun May 03, 2015 8:43 pm
by frafrichile
WebPi wrote:This is a problem with the permission of the SPI interface. I think it's owned by root, but your script is running as Apache's user name, www-data. You need to give www-data access to SPI.
awesome.
I am trying this at the moment but the group "spi" does not exist. thats the message I get
Thank you !
Posted: Fri May 08, 2015 5:41 pm
by frafrichile
I still cannot figure it out :/
I tried adding the user but nothing.
[email protected] /usr/lib/cgi-bin $ sudo adduser www-data spi
adduser: The group `spi' does not exist.
[email protected] /usr/lib/cgi-bin $ sudo addgroup spi
Adding group `spi' (GID 1002) ...
Done.
Adding user `www-data' to group `spi' ...
Adding user www-data to group spi
Done.
any ideas?
Posted: Fri May 08, 2015 6:03 pm
by joan
There is no point in adding a spi group as it won't help, if it's relevant the group would already exist.
You need to look at the spi device and see the access permissions.
What is reported by
ls -l /dev/spi*
My Pi2 shows
crw-rw---- 1 root spi 153, 0 May  7 22:57 /dev/spidev0.0
crw-rw---- 1 root spi 153, 1 May  7 22:57 /dev/spidev0.1
Posted: Fri May 08, 2015 6:12 pm
by frafrichile
joan wrote:There is no point in adding a spi group as it won't help, if it's relevant the group would already exist.
What is reported by
ls -l /dev/spi*
My Pi2 shows
this is what mine reads
crw------- 1 root root 153, 0 Dec 31  1969 /dev/spidev0.0
crw------- 1 root root 153, 1 Dec 31  1969 /dev/spidev0.1
date seems weird.
Posted: Fri May 08, 2015 6:19 pm
by DougieLawson
sudo apt-get update && sudo apt-get dist-upgrade
will get your system updated (to the new Raspbian stuff as at yesterday) and one of the new packages will add the spi group and will add the pi user to the spi group.
Posted: Fri May 08, 2015 6:50 pm
by joan
DougieLawson wrote:sudo apt-get update && sudo apt-get dist-upgrade
...but make sure you delete the spi group you created before doing this.
Posted: Sat May 09, 2015 4:39 pm
by frafrichile
Did all the above.
Still having the same problem :/
<type 'exceptions.IOError'>	Python 2.7.3: /usr/bin/python
Sat May 9 11:38:25 2015
A problem occurred in a Python script. Here is the sequence of function calls leading up to the error, in the order they occurred.
 /usr/lib/cgi-bin/mcp3008.py in ()
     23 # Open SPI bus
     24 spi = spidev.SpiDev()
=>   25 spi.open(0,0)
     26
     27 # Function to read SPI data from MCP3008 chip
spi = <SpiDev object>, spi.open = <built-in method open of SpiDev object>
<type 'exceptions.IOError'>: [Errno 13] Permission denied
      args = (13, 'Permission denied')
      errno = 13
      filename = None
      message = ''
      strerror = 'Permission denied
