vectraboyv6
voicecommand best mic poll
Thu Mar 26, 2015 3:15 pm
Im now using steven hickson amazing voice command software. Im only using a very cheap usb microphone, its like a 5mm bit of plastic on the end of a usb connector. So the question is what and how good was the microphone you used?
ta
Tarcas
Re: voicecommand best mic poll
Sat Mar 28, 2015 1:07 am
I used an inexpensive webcam with built-in mic. It worked fairly well from about 10-15 feet (3-5 meters) away, but it was positioned directly under a TV, and whenever the TV was on it was completely useless due to the nearby noise.
johnsonld123
Tue Apr 21, 2015 9:38 pm
I tried both usb webcam and a soundcard with a 3.5mm open mic. I get the same results as Tarcas. I'm hoping some one figures out how to use a bluetooth mic.
RPi-Debian-SiriProxy-2013-02-16
