Python Based Self-Balancing Robot using MPU6050
Posted: Sat Feb 28, 2015 5:04 pm
Hello Everybody,
I am trying to build a Self-Balancing Robot ( nothing new ) but i am trying to build this Robot with Python Code . I am half way gone , i think . My robot is moving back and forth but it fails to maintain the balance . I am doing some wrong calculation on the PID and Accelerometer Angle , i think but didn’t find out the Error . I need the community Help
The Parts I am using is :
1. RPi B+
2. GY-521 MPU-6050 Module 3 axial gyroscope accelerometer stance tilt http://www.amazon.com/Kootek-Arduino-MP ... B008BOPN40
3. 2 DC Motor 12v 600RPM http://www.dfrobot.com/index.php?route= ... uct_id=354
4. 2 Wheels http://www.dfrobot.com/index.php?route= ... uct_id=353
5. L298N Dual H-Bridge Motor Control & Drives Module http://www.amazon.com/gp/product/B00CAG6GX2
Robotics is kind a hobby and i bought Raspberry Pi B+ few weeks ago , since it is very hard to get in my country. I am trying to google and read about the whole process and theory behind the self-balancing robot and also reading code ( I found c and c++ mostly ) that i can not fully understand . I love python and i am trying to write the code for this robot in Python only . I am also having trouble doing the PWM for the DC motor i choose
Here is the full Source Code
https://github.com/thebdcoder/balancebot.git
I have managed to get the MPU6050 Library from
https://github.com/bitify/raspi/tree/ma ... on/sensors
I also Found a PID library for Python and using it . Saw many user using it for Quadcopter Project
All those Library are in the 6050 folder in the Git Repository
Here is the final Code
Here is some sample output of this Code :
gyroAngleX -35.93 gyroAngleY 18.26 accAngX 67.76 CFangleX 118.11 | accAngX1 -16.12 CFangleX1 -19.99 | pid : -0.01
I am using CFangleX1 for PID . I have used Complimentary Filter for CFangleX1 angle
I am not sure the angle i am getting is quite right and also the pid calculation . This is my first project .
One more challenge i am facing is controlling Motor Speed using Python GPIO.PWM .
The approach i am following is :
This working so far but not quite sure that the PID is the DutyCycle that i sould send . I saw in many Cpp code that it sends the output between -255 to 255 . What i am doing for python is if pid is positive then move forward else backward ( if backward then move backward but convert pid/speed to positive (pid * -1) because it can only take int between 0 to 100 ) .
The Article i am reading on and on is :
http://letsmakerobots.com/node/38610
http://www.instructables.com/id/Self-Ba ... /?ALLSTEPS
http://blog.bitify.co.uk/2013/11/using- ... mbine.html
http://ozzmaker.com/2013/04/18/success- ... pberry-pi/
They are all Good but none of them Provide Sample Output . Some article with Source Code But like I Said all in .ino ( C & Cpp )
I Really need to solve it . I hope you understand the point and if not let me know which . I am waiting for the help of this community .
1. RPi B+
#!/usr/bin/python
import smbus
import math
import time
from MPU6050 import MPU6050
from PID import PID
import motor as MOTOR
gyro_scale = 131.0
accel_scale = 16384.0
RAD_TO_DEG = 57.29578
M_PI = 3.14159265358979323846
address = 0x68 # This is the address value read via the i2cdetect command
bus = smbus.SMBus(1) # or bus = smbus.SMBus(1) for Revision 2 boards
now = time.time()
K = 0.98
K1 = 1 - K
time_diff = 0.01
sensor = MPU6050(bus, address, "MPU6050")
sensor.read_raw_data() # Reads current data from the sensor
rate_gyroX = 0.0
rate_gyroY = 0.0
rate_gyroZ = 0.0
gyroAngleX = 0.0
gyroAngleY = 0.0
gyroAngleZ = 0.0
raw_accX = 0.0
raw_accY = 0.0
raw_accZ = 0.0
rate_accX = 0.0
rate_accY = 0.0
rate_accZ = 0.0
accAngX = 0.0
CFangleX = 0.0
CFangleX1 = 0.0
K = 0.98
FIX = -12.89
#print "{0:.4f} {1:.2f} {2:.2f} {3:.2f} {4:.2f} {5:.2f} {6:.2f}".format( time.time() - now, (last_x), gyro_total_x, (last_x), (last_y), gyro_total_y, (last_y))
def dist(a, b):
return math.sqrt((a * a) + (b * b))
def get_y_rotation(x,y,z):
radians = math.atan2(x, dist(y,z))
return -math.degrees(radians)
def get_x_rotation(x,y,z):
radians = math.atan2(y, dist(x,z))
return math.degrees(radians)
p=PID(1.0,-0.04,0.0)
p.setPoint(0.0)
for i in range(0, int(300.0 / time_diff)):
time.sleep(time_diff - 0.005)
# Gyroscope value Degree Per Second / Scalled Data
rate_gyroX = sensor.read_scaled_gyro_x()
rate_gyroY = sensor.read_scaled_gyro_y()
rate_gyroZ = sensor.read_scaled_gyro_z()
# The angle of the Gyroscope
gyroAngleX += rate_gyroX * time_diff
gyroAngleY += rate_gyroY * time_diff
gyroAngleZ += rate_gyroZ * time_diff
# Accelerometer Raw Value
raw_accX = sensor.read_raw_accel_x()
raw_accY = sensor.read_raw_accel_y()
raw_accZ = sensor.read_raw_accel_z()
# Accelerometer value Degree Per Second / Scalled Data
rate_accX = sensor.read_scaled_accel_x()
rate_accY = sensor.read_scaled_accel_y()
rate_accZ = sensor.read_scaled_accel_z()
# http://ozzmaker.com/2013/04/18/success-with-a-balancing-robot-using-a-raspberry-pi/
accAngX = ( math.atan2(rate_accX, rate_accY) + M_PI ) * RAD_TO_DEG
CFangleX = K * ( CFangleX + rate_gyroX * time_diff) + (1 - K) * accAngX
# http://blog.bitify.co.uk/2013/11/reading-data-from-mpu-6050-on-raspberry.html
accAngX1 = get_x_rotation(rate_accX, rate_accY, rate_accX)
CFangleX1 = ( K * ( CFangleX1 + rate_gyroX * time_diff) + (1 - K) * accAngX1 )
# Followed the Second example because it gives resonable pid reading
pid = p.update(CFangleX1)
if(pid > 0):
MOTOR.forward(pid)
else:
MOTOR.backward( (pid*-1) )
print "{0:.2f} {1:.2f} {2:.2f} {3:.2f} | {4:.2f} {5:.2f} | {6:.2f}".format( gyroAngleX, gyroAngleY , accAngX, CFangleX, accAngX1, CFangleX1, pid)
-35.93 18.26 67.76 118.11 | -16.12 -19.99 | -0.01
-35.40 18.26 68.50 117.64 | -15.57 -19.38 | -0.62
-34.86 18.25 101.47 117.84 | 8.16 -18.31 | -1.69
-34.31 18.25 99.83 118.03 | 6.98 -17.26 | -2.74
-33.75 18.25 137.20 118.96 | 37.36 -15.61 | -4.39
-33.19 18.26 145.63 120.04 | 45.95 -13.83 | -6.17
-32.61 18.26 153.73 121.28 | 55.08 -11.89 | -8.11
-32.02 18.26 165.55 122.74 | 69.98 -9.67 | -10.33
-31.42 18.26 44.88 121.77 | -35.38 -9.61 | -10.39
-31.05 18.27 185.88 123.42 | 81.72 -7.41 | -12.59
-30.59 18.29 83.42 123.07 | -4.66 -6.91 | -13.09
-30.18 18.30 28.81 121.59 | -52.12 -7.41 | -12.59
-29.77 18.30 140.66 122.37 | 40.78 -6.04 | -13.96
-29.36 18.30 89.12 122.11 | -0.62 -5.53 | -14.47
-28.96 18.30 45.39 120.96 | -34.90 -5.73 | -14.27
-28.56 18.30 166.50 122.26 | 71.24 -3.80 | -16.20
-28.11 18.31 163.19 123.53 | 66.87 -1.94 | -18.06
-27.75 18.33 51.13 122.43 | -29.68 -2.15 | -17.85
-27.40 18.35 147.70 123.28 | 48.21 -0.80 | -19.20
-27.07 18.37 25.34 121.65 | -56.20 -1.58 | -18.42
-26.73 18.38 178.36 123.11 | 87.68 0.54 | -20.52
-26.45 18.42 18.66 121.30 | -64.48 -0.49 | -19.51
-26.21 18.45 317.37 125.45 | -37.53 -0.99 | -19.01
-26.00 18.49 191.33 126.98 | 74.19 0.72 | -20.69
-25.85 18.47 161.86 127.82 | 65.14 2.15 | -22.03
-25.76 18.47 185.21 129.06 | 82.65 3.85 | -23.58
-25.68 18.45 176.29 130.08 | 84.76 5.55 | -25.06
-25.65 18.43 171.29 130.93 | 77.77 7.02 | -26.25
-25.75 18.43 172.08 131.66 | 78.86 8.36 | -27.26
-25.90 18.43 162.56 132.13 | 66.05 9.37 | -27.89
-26.11 18.43 140.49 132.09 | 40.61 9.78 | -27.91
-26.33 18.43 187.97 132.99 | 78.80 10.95 | -28.64
-26.58 18.48 128.25 132.66 | 29.13 11.07 | -28.32
-26.88 18.55 168.54 133.08 | 74.00 12.03 | -28.80
-27.17 18.59 177.89 133.69 | 87.01 13.25 | -29.49
-27.48 18.62 170.87 134.12 | 77.19 14.22 | -29.89
-27.85 18.63 163.88 134.36 | 67.77 14.94 | -30.00
-28.23 18.64 169.18 134.68 | 74.88 15.76 | -30.20
-28.64 18.68 178.51 135.16 | 87.90 16.80 | -30.57
-29.11 18.72 174.15 135.48 | 81.75 17.64 | -30.70
-29.59 18.73 161.26 135.52 | 64.37 18.10 | -30.44
-30.10 18.73 176.95 135.86 | 85.70 18.96 | -30.54
-30.67 18.73 168.62 135.95 | 74.11 19.50 | -30.30
-31.27 18.73 167.82 136.00 | 73.03 19.98 | -29.98
-31.88 18.75 169.39 136.07 | 75.16 20.49 | -29.67
-32.53 18.77 170.35 136.12 | 76.48 20.97 | -29.31
-33.20 18.79 182.87 136.39 | 85.95 21.61 | -29.09
-33.89 18.80 172.46 136.44 | 79.40 22.09 | -28.68
-34.59 18.80 111.92 135.26 | 15.89 21.28 | -27.02
-35.29 18.83 183.87 135.55 | 84.53 21.86 | -26.73
-36.01 18.85 169.86 135.53 | 75.81 22.23 | -26.21
-36.74 18.87 98.80 134.09 | 6.25 21.20 | -24.33
-37.48 18.91 139.77 133.47 | 39.89 20.85 | -23.15
-38.16 18.91 18.53 130.51 | -64.64 18.47 | -20.03
-38.89 18.96 55.18 128.29 | -26.19 16.87 | -17.75
-39.59 18.98 106.23 127.16 | 11.63 16.07 | -16.31
-40.28 19.01 33.70 124.61 | -46.67 14.15 | -13.82
-40.99 19.02 9.04 121.60 | -77.32 11.61 | -10.82
-41.72 19.01 144.39 121.34 | 44.63 11.56 | -10.31
-42.43 19.02 178.07 121.79 | 87.27 12.38 | -10.63
-43.12 19.04 86.89 120.41 | -2.20 11.42 | -9.21
-43.83 19.06 24.05 117.79 | -57.75 9.33 | -6.76
-44.60 19.07 38.60 115.45 | -41.53 7.56 | -4.68
-45.41 19.08 21.05 112.76 | -61.45 5.39 | -2.29
-46.28 19.10 19.55 110.05 | -63.34 3.16 | 0.06
-47.19 19.10 168.62 110.32 | 74.11 3.68 | -0.31
-47.92 19.14 147.37 110.36 | 47.84 3.86 | -0.33
-48.69 19.16 347.73 114.35 | -72.91 1.56 | 2.02
-49.44 19.18 44.87 112.22 | -35.39 0.09 | 3.50
GPIO.setup(21, GPIO.OUTPUT)
GPIO.PWM(21, 100)
GPIO.start(PID) # the Duty Cycle between ( 1 to 100 )
