I am trying to build a Self-Balancing Robot ( nothing new ) but i am trying to build this Robot with Python Code . I am half way gone , i think . My robot is moving back and forth but it fails to maintain the balance . I am doing some wrong calculation on the PID and Accelerometer Angle , i think but didn’t find out the Error . I need the community Help
The Parts I am using is :
1. RPi B+
2. GY-521 MPU-6050 Module 3 axial gyroscope accelerometer stance tilt http://www.amazon.com/Kootek-Arduino-MP ... B008BOPN40
3. 2 DC Motor 12v 600RPM http://www.dfrobot.com/index.php?route= ... uct_id=354
4. 2 Wheels http://www.dfrobot.com/index.php?route= ... uct_id=353
5. L298N Dual H-Bridge Motor Control & Drives Module http://www.amazon.com/gp/product/B00CAG6GX2
Robotics is kind a hobby and i bought Raspberry Pi B+ few weeks ago , since it is very hard to get in my country. I am trying to google and read about the whole process and theory behind the self-balancing robot and also reading code ( I found c and c++ mostly ) that i can not fully understand . I love python and i am trying to write the code for this robot in Python only . I am also having trouble doing the PWM for the DC motor i choose
Here is the full Source Code
https://github.com/thebdcoder/balancebot.git
I have managed to get the MPU6050 Library from
https://github.com/bitify/raspi/tree/ma ... on/sensors
I also Found a PID library for Python and using it . Saw many user using it for Quadcopter Project
All those Library are in the 6050 folder in the Git Repository
Here is the final Code
#!/usr/bin/python
import smbus
import math
import time
from MPU6050 import MPU6050
from PID import PID
import motor as MOTOR
gyro_scale = 131.0
accel_scale = 16384.0
RAD_TO_DEG = 57.29578
M_PI = 3.14159265358979323846
address = 0x68 # This is the address value read via the i2cdetect command
bus = smbus.SMBus(1) # or bus = smbus.SMBus(1) for Revision 2 boards
now = time.time()
K = 0.98
K1 = 1 - K
time_diff = 0.01
sensor = MPU6050(bus, address, "MPU6050")
sensor.read_raw_data() # Reads current data from the sensor
rate_gyroX = 0.0
rate_gyroY = 0.0
rate_gyroZ = 0.0
gyroAngleX = 0.0
gyroAngleY = 0.0
gyroAngleZ = 0.0
raw_accX = 0.0
raw_accY = 0.0
raw_accZ = 0.0
rate_accX = 0.0
rate_accY = 0.0
rate_accZ = 0.0
accAngX = 0.0
CFangleX = 0.0
CFangleX1 = 0.0
K = 0.98
FIX = -12.89
#print "{0:.4f} {1:.2f} {2:.2f} {3:.2f} {4:.2f} {5:.2f} {6:.2f}".format( time.time() - now, (last_x), gyro_total_x, (last_x), (last_y), gyro_total_y, (last_y))
def dist(a, b):
return math.sqrt((a * a) + (b * b))
def get_y_rotation(x,y,z):
radians = math.atan2(x, dist(y,z))
return -math.degrees(radians)
def get_x_rotation(x,y,z):
radians = math.atan2(y, dist(x,z))
return math.degrees(radians)
p=PID(1.0,-0.04,0.0)
p.setPoint(0.0)
for i in range(0, int(300.0 / time_diff)):
time.sleep(time_diff - 0.005)
# Gyroscope value Degree Per Second / Scalled Data
rate_gyroX = sensor.read_scaled_gyro_x()
rate_gyroY = sensor.read_scaled_gyro_y()
rate_gyroZ = sensor.read_scaled_gyro_z()
# The angle of the Gyroscope
gyroAngleX += rate_gyroX * time_diff
gyroAngleY += rate_gyroY * time_diff
gyroAngleZ += rate_gyroZ * time_diff
# Accelerometer Raw Value
raw_accX = sensor.read_raw_accel_x()
raw_accY = sensor.read_raw_accel_y()
raw_accZ = sensor.read_raw_accel_z()
# Accelerometer value Degree Per Second / Scalled Data
rate_accX = sensor.read_scaled_accel_x()
rate_accY = sensor.read_scaled_accel_y()
rate_accZ = sensor.read_scaled_accel_z()
# http://ozzmaker.com/2013/04/18/success-with-a-balancing-robot-using-a-raspberry-pi/
accAngX = ( math.atan2(rate_accX, rate_accY) + M_PI ) * RAD_TO_DEG
CFangleX = K * ( CFangleX + rate_gyroX * time_diff) + (1 - K) * accAngX
# http://blog.bitify.co.uk/2013/11/reading-data-from-mpu-6050-on-raspberry.html
accAngX1 = get_x_rotation(rate_accX, rate_accY, rate_accX)
CFangleX1 = ( K * ( CFangleX1 + rate_gyroX * time_diff) + (1 - K) * accAngX1 )
# Followed the Second example because it gives resonable pid reading
pid = p.update(CFangleX1)
if(pid > 0):
MOTOR.forward(pid)
else:
MOTOR.backward( (pid*-1) )
print "{0:.2f} {1:.2f} {2:.2f} {3:.2f} | {4:.2f} {5:.2f} | {6:.2f}".format( gyroAngleX, gyroAngleY , accAngX, CFangleX, accAngX1, CFangleX1, pid)
gyroAngleX -35.93 gyroAngleY 18.26 accAngX 67.76 CFangleX 118.11 | accAngX1 -16.12 CFangleX1 -19.99 | pid : -0.01
-35.93 18.26 67.76 118.11 | -16.12 -19.99 | -0.01
-35.40 18.26 68.50 117.64 | -15.57 -19.38 | -0.62
-34.86 18.25 101.47 117.84 | 8.16 -18.31 | -1.69
-34.31 18.25 99.83 118.03 | 6.98 -17.26 | -2.74
-33.75 18.25 137.20 118.96 | 37.36 -15.61 | -4.39
-33.19 18.26 145.63 120.04 | 45.95 -13.83 | -6.17
-32.61 18.26 153.73 121.28 | 55.08 -11.89 | -8.11
-32.02 18.26 165.55 122.74 | 69.98 -9.67 | -10.33
-31.42 18.26 44.88 121.77 | -35.38 -9.61 | -10.39
-31.05 18.27 185.88 123.42 | 81.72 -7.41 | -12.59
-30.59 18.29 83.42 123.07 | -4.66 -6.91 | -13.09
-30.18 18.30 28.81 121.59 | -52.12 -7.41 | -12.59
-29.77 18.30 140.66 122.37 | 40.78 -6.04 | -13.96
-29.36 18.30 89.12 122.11 | -0.62 -5.53 | -14.47
-28.96 18.30 45.39 120.96 | -34.90 -5.73 | -14.27
-28.56 18.30 166.50 122.26 | 71.24 -3.80 | -16.20
-28.11 18.31 163.19 123.53 | 66.87 -1.94 | -18.06
-27.75 18.33 51.13 122.43 | -29.68 -2.15 | -17.85
-27.40 18.35 147.70 123.28 | 48.21 -0.80 | -19.20
-27.07 18.37 25.34 121.65 | -56.20 -1.58 | -18.42
-26.73 18.38 178.36 123.11 | 87.68 0.54 | -20.52
-26.45 18.42 18.66 121.30 | -64.48 -0.49 | -19.51
-26.21 18.45 317.37 125.45 | -37.53 -0.99 | -19.01
-26.00 18.49 191.33 126.98 | 74.19 0.72 | -20.69
-25.85 18.47 161.86 127.82 | 65.14 2.15 | -22.03
-25.76 18.47 185.21 129.06 | 82.65 3.85 | -23.58
-25.68 18.45 176.29 130.08 | 84.76 5.55 | -25.06
-25.65 18.43 171.29 130.93 | 77.77 7.02 | -26.25
-25.75 18.43 172.08 131.66 | 78.86 8.36 | -27.26
-25.90 18.43 162.56 132.13 | 66.05 9.37 | -27.89
-26.11 18.43 140.49 132.09 | 40.61 9.78 | -27.91
-26.33 18.43 187.97 132.99 | 78.80 10.95 | -28.64
-26.58 18.48 128.25 132.66 | 29.13 11.07 | -28.32
-26.88 18.55 168.54 133.08 | 74.00 12.03 | -28.80
-27.17 18.59 177.89 133.69 | 87.01 13.25 | -29.49
-27.48 18.62 170.87 134.12 | 77.19 14.22 | -29.89
-27.85 18.63 163.88 134.36 | 67.77 14.94 | -30.00
-28.23 18.64 169.18 134.68 | 74.88 15.76 | -30.20
-28.64 18.68 178.51 135.16 | 87.90 16.80 | -30.57
-29.11 18.72 174.15 135.48 | 81.75 17.64 | -30.70
-29.59 18.73 161.26 135.52 | 64.37 18.10 | -30.44
-30.10 18.73 176.95 135.86 | 85.70 18.96 | -30.54
-30.67 18.73 168.62 135.95 | 74.11 19.50 | -30.30
-31.27 18.73 167.82 136.00 | 73.03 19.98 | -29.98
-31.88 18.75 169.39 136.07 | 75.16 20.49 | -29.67
-32.53 18.77 170.35 136.12 | 76.48 20.97 | -29.31
-33.20 18.79 182.87 136.39 | 85.95 21.61 | -29.09
-33.89 18.80 172.46 136.44 | 79.40 22.09 | -28.68
-34.59 18.80 111.92 135.26 | 15.89 21.28 | -27.02
-35.29 18.83 183.87 135.55 | 84.53 21.86 | -26.73
-36.01 18.85 169.86 135.53 | 75.81 22.23 | -26.21
-36.74 18.87 98.80 134.09 | 6.25 21.20 | -24.33
-37.48 18.91 139.77 133.47 | 39.89 20.85 | -23.15
-38.16 18.91 18.53 130.51 | -64.64 18.47 | -20.03
-38.89 18.96 55.18 128.29 | -26.19 16.87 | -17.75
-39.59 18.98 106.23 127.16 | 11.63 16.07 | -16.31
-40.28 19.01 33.70 124.61 | -46.67 14.15 | -13.82
-40.99 19.02 9.04 121.60 | -77.32 11.61 | -10.82
-41.72 19.01 144.39 121.34 | 44.63 11.56 | -10.31
-42.43 19.02 178.07 121.79 | 87.27 12.38 | -10.63
-43.12 19.04 86.89 120.41 | -2.20 11.42 | -9.21
-43.83 19.06 24.05 117.79 | -57.75 9.33 | -6.76
-44.60 19.07 38.60 115.45 | -41.53 7.56 | -4.68
-45.41 19.08 21.05 112.76 | -61.45 5.39 | -2.29
-46.28 19.10 19.55 110.05 | -63.34 3.16 | 0.06
-47.19 19.10 168.62 110.32 | 74.11 3.68 | -0.31
-47.92 19.14 147.37 110.36 | 47.84 3.86 | -0.33
-48.69 19.16 347.73 114.35 | -72.91 1.56 | 2.02
-49.44 19.18 44.87 112.22 | -35.39 0.09 | 3.50
I am not sure the angle i am getting is quite right and also the pid calculation . This is my first project .
One more challenge i am facing is controlling Motor Speed using Python GPIO.PWM .
The approach i am following is :
GPIO.setup(21, GPIO.OUTPUT)
GPIO.PWM(21, 100)
GPIO.start(PID) # the Duty Cycle between ( 1 to 100 )
The Article i am reading on and on is :
http://letsmakerobots.com/node/38610
http://www.instructables.com/id/Self-Ba ... /?ALLSTEPS
http://blog.bitify.co.uk/2013/11/using- ... mbine.html
http://ozzmaker.com/2013/04/18/success- ... pberry-pi/
They are all Good but none of them Provide Sample Output . Some article with Source Code But like I Said all in .ino ( C & Cpp )
I Really need to solve it . I hope you understand the point and if not let me know which . I am waiting for the help of this community .
