charmflex
Control 8 35kg servos using raspberry pi with external power supply, how?
Thu Jun 24, 2021 5:20 am
Hello. I want to build a quadruped robot with 8 high torque servos (operating voltage: 4.8v ~ 6v). I have two 18650 batteries, with total of 7.4v.
I want to power those servos with these battery, but since the voltage is 7.4v, which will damage those servos, I decide to use 5v regulator in the circuit. However, the servo motors will also draw a lot of current. From what I surveyed, 1A per servo motor would be common condition. So I would expect I need 10A in the circuit. Which and how many regulators should I buy, and how to build, in order to sustain 10A current?
In simple word, I need to step down the voltage to 5v from 7.4v, how should I build the circuit in order to run 8 high torque servo motors with external power supply?
Thanks in advance.
LTolledo
Re: Control 8 35kg servos using raspberry pi with external power supply, how?
Thu Jun 24, 2021 11:51 am
what is the ampere-hour rating of your 18650 cell?
and what RPi model are you going to use?
Some people be like:
charmflex
Thu Jun 24, 2021 1:50 pm
The battery is 3000mah, I have two, so total is 6000mah. I use raspberry pi 4.
I checked out that battery has c rating. Does it mean that each battery can only output up to certain limit of current?
LTolledo
Thu Jun 24, 2021 9:18 pm
if used in series to get 7.4v, the capacity theoretically remains at 3000mAh
if used in parallel at 3.7v, the capacity will theoretically go up to 6000mAh
3000mAh / 10A = 0.3h = 18 minutes theoretically, but you'll get much less than that
so not enough juice!
also I doubt a 18650 cell can give 10A without eventually exploding!... so its a safety concern!
get a bigger capacity battery, like the ones used for RC cars/airplanes.
some are rated 6000mAh at 7.4v
each servo need to have its own battery + buck converter
the RPi will also need to have its own battery + buck converter
or if you really want longer operating hours in a single battery, get an 8D instead...
start calculating the cost to do the project....
or re-think the requirements for the project.
charmflex
Fri Jun 25, 2021 8:43 am
Each servo need a bulk convertor? Why not use 1 bulk convertor with all 8 servos?
I also dont mind if it run for how long, as long as the robot can move...
LTolledo
Fri Jun 25, 2021 11:37 am
do as you wish, and see what happens...
