killwater
Controlling 5V fan from GPIO pin with PWM
Sat Jun 12, 2021 9:51 pm
I am trying to control a 5V 3pin fan from GPIO with PWM control. It works at full speed if I connect it directly to 5V pin and ground. However if I try to control it from GPIO 12 it does not work.
I am using a Bi-directional 4 channel logic level shifter from ebay.
I get 5V on fan terminal if the fan is disconnected. When I connect it to the fan it will only move a tiny bit and stop. At the moment I am trying to run it at full speed without the PWM control.
I am working under assumption that GPIO12 only provides a control signal to the logic shifter and it turns on/off current flow from 5V pin so cannot understand what mistake am I making.
The connections look like the below:
GPIO12 --------------- LV2 LOGIC SHIFTER HV2 ----------------- FAN +
GROUND--------------GND LOGIC SHIFTER GND ----------------- FAN -
3V3----------------------LV LOGIC SHIFTER HV-----------]
5V-----------------------------------------------------------------------]
Thank you in advance
Michal
vffgaston
Re: Controlling 5V fan from GPIO pin with PWM
Sun Jun 13, 2021 6:27 am
The chip you are using just shifts logic levels: it does not provide an output current big enough as to move your fan.
What you need is a "driver", perhaps a npn transistor or similar.
killwater
Sun Jun 13, 2021 8:13 am
I thought I am limited to the smaller of 5V pin max current or the chip rating as it works as a high frequency switch. What is the maximum current I can draw? The fan is rated at 0.15A.
pcmanbob
Mon Jun 14, 2021 2:49 pm
To control you fan you need to use a transistor like this.
it assumes the 3rd wire is just for speed output.
killwater
Tue Jun 15, 2021 6:20 pm
Thank you very much, both of you.
killwater
Sun Jun 20, 2021 11:43 pm
Jsut one more question - can I use S8050 instead of 2n2222? Would 1k resistor still be sufficient?
Imperf3kt
Contact: Twitter
Mon Jun 21, 2021 12:29 am
Note that the third wire is an output from the fan, not an input. Do not connect it to your Pi.
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
pcmanbob
Mon Jun 21, 2021 10:20 am
The transistor will carry the load of the fan but you may have to lower the resistor value to obtain full voltage/current to the fan.
killwater
Mon Jun 21, 2021 11:01 pm
Works well. i managed to get it change the speed and I got full power as far as I can tell. Thank you.
The only problem I have now is it makes a lot of high pitched noise if it deos not work at 100%. I expected a little bit of humming but it can be heard from adjacent room. Is it because I used the S8050 instead of 2N2222?
pcmanbob
Tue Jun 22, 2021 7:03 am
What frequency did you set the pwm to ?
Try changing it to some thing else 50 or 100 are what people tend to use.
vffgaston
Tue Jun 22, 2021 7:07 am
Absolutely no. The main problem the transistor may produce is a noticeable (use your fingers) auto-heating. I guess the problem comes from the very fact that you are using a PWM audible frecueny. Try to change it over, say, 10.000 Hz (although your dog -and young boys- may keep hearing it).
killwater
Tue Jun 22, 2021 4:39 pm
I went down to 100Hz and it seams to be much better. Thank you.
