MichelTrahan
Using MQTT with gpiozero
Tue May 18, 2021 3:33 pm
I have built a library over the gpiozero to use MQTT without coding. You just define what is connected to the raspberry pi (zero, 2, 3, 4, 400) using an XML ... the library does the rest ... zero code
If you are interested, go see https://github.com/gpiozero4mqtt/gpiozero4mqtt it is open source !
