tesla000
Tips on sending sensor data from esp32 to rpi3 with wifi bor luetooth
Tue May 11, 2021 9:49 pm
I have a project to do, i'm gonna measure temperature and humidity from bme280, i need help with sending the readings from esp32 to to rpi3, first of all idk if i should i use bluetooth or wifi?, i was thinking of bluetooth, making rpi3 discoverable and then program the esp32 to send data and the rpi to save them in a file, or over wifi by running a tcp server on rpi and then make esp32 connect to it and send data, would be a big help if somebody could give me a few reccomendations on how to do this, didn't find much information on the internet about this, or would using wifi be a better option?
best regards
ghp
Re: Tips on sending sensor data from esp32 to rpi3 with wifi bor luetooth
Wed May 12, 2021 12:19 pm
MQTT (using wifi) is the perfect option.
There are many tutorials in the net.
https://diyi0t.com/microcontroller-to-r ... unication/
MQTT libraries are available for ESP32.
