lnimon
Measure fan speed?
Fri Apr 16, 2021 7:16 pm
I want to create a rudimentary air flow measurement sensor. Can I take a normal CPU fan, connect the fan speed wire to a GPIO, and then measure the fan speed that way? I don't need high accuracy or even real numbers, I just want to compare air flow between two sources (see which one is more powerful).
ghp
Re: Measure fan speed?
Sat Apr 17, 2021 6:00 am
blimpyway
Sat Apr 17, 2021 10:00 pm
You can try to use the tacho signal line but I doubt it works without powering the fan. And if it is powered, the fan will spin on its own more than from wind's airflow
drtechno
Sat May 01, 2021 5:16 am
You should be able to use the rpm/tach circuit. But it will requiring a pull up resistor on the gpio line to 3V. A 1K resistor will work just fine for that. So the two wires you would have to connect is the Gnd and RPM from that fan.
