Socialmedia
multiple sabertooth controlled by raspberry pi
Mon Aug 03, 2020 8:31 pm
hi everyone,
recently I've been working on a robot and I have had issues with using multiple sabertooth motor controllers with a raspberry pi 3b+. I have had success controlling just one sabertooth 2x60 but as soon as I tried controlling another sabertooth, the system crashed and now my original code won't work for any of my sabertooth motor controllers. bellow is my code. the only thing I changed to try and get the raspberry pi to work with another sabertooth controller is changing the GPIO outputs. thanks for the help guys!
import RPi.GPIO as GPIO
import time
PIN_MOTOR1=12 #S1
PIN_MOTOR2=19 #S2
try:
    while True:
        GPIO.setmode(GPIO.BCM)
        GPIO.setwarnings(False)
        GPIO.setup(PIN_MOTOR1, GPIO.OUT)
        GPIO.setup(PIN_MOTOR2, GPIO.OUT)
        GPIO.output(12,GPIO.HIGH)
        GPIO.output(19,GPIO.LOW)
        motor1 = GPIO.PWM(PIN_MOTOR1,1000)
        motor2 = GPIO.PWM(PIN_MOTOR2,1000)
    #go forward
        motor1.start(100)
        motor2.start(100)
    #GPIO.output(PIN_MOTOR1,GPIO.HIGH)
        time.sleep(1000)
    #go back
        motor1.start(25)
        motor2.start(25)
    #GPIO.output(PIN_MOTOR1,GPIO.LOW)
        time.sleep(5)
    #stop
        motor1.stop()
        motor2.stop()
except KeyboardInterrupt :
    pass
except :
    GPIO.cleanup()
    raise
GPIO.cleanup()
rpiMike
Re: multiple sabertooth controlled by raspberry pi
Thu Aug 06, 2020 9:40 pm
Why are you using 2 sabertooth controllers?
How have you wired 2 controllers to the Pi?
Socialmedia
Sun Aug 09, 2020 9:08 pm
first off, they are all connected through a level converter, then the S! and S2 connections are connected to different GPIO pins. doe sthat answer your question. also sorry for answering so late
rpiMike
Sun Aug 09, 2020 9:34 pm
No, you didn’t answer why you need 2 controllers.
As far as I am aware the Pi3B+ only has one serial interface on the GPIO pins, so you can only connect one controller to GPIO.
Socialmedia
Sun Aug 09, 2020 11:19 pm
for my project, I need to control four motors for the drive, two motors for the arm, and one motor for a grip. I just thought I could control three sabertooth motor controllers from the raspi. is there a better way to do this?
rpiMike
Mon Aug 10, 2020 7:11 am
You could connect the 2nd controller with a serial to usb converter.
joan
Mon Aug 10, 2020 7:33 am
What control mode do you want to use? You can send servo pulses to S1 and S2 to separately control the two motors on one controller.
Socialmedia
Mon Aug 10, 2020 2:42 pm
but can I do that with one raspberry pi for three separate motor controllers?
joan
Mon Aug 10, 2020 2:55 pm
@Socialmedia
Yes, if you are talking about sending servo pulses to 3 controllers (i.e. six different servo pulses).
Socialmedia
Mon Aug 10, 2020 3:11 pm
okay, cool. so what mode would this be? sorry for the rudimentary questions I just started to learn programming.
joan
Mon Aug 10, 2020 3:21 pm
This isn't a software mode, it's an operation mode of the sabretooth 2x60 controller according to its pdf.
I am assuming you know the mode you are currently using.
Socialmedia
Mon Aug 10, 2020 3:24 pm
I am in serial mode rn
Socialmedia
Mon Aug 10, 2020 3:27 pm
Ahhh. I see that now, thank you
