I have been researching around it most temperature sensors are analog based from what I have read meaning you need a Arduino between the sensor and the Pi (RPi3 in my case).
I have bought one of these sensors: https://www.ebay.co.uk/itm/Digital-Wate ... 2749.l2649 and was wondering if I could open it up and solder it directly to some of the Pi pins?
Would that work? I could be wrong but as its a 'Digital' sensor then it should work with the Pi? If so, which pins etc would I need to use? I have a volt meter so I can check the internals of the sensor. I also don't mind butchering it (no display etc) just so I can get some readings into the Pi which would then display on Home Assistant (that's a separate matter which I am happy doing).
Cheers
