GregH2O
DHT22 and Raspberry Pi 4 b
Sat May 23, 2020 2:22 pm
First time post, first time Pi user. I want to connect up a DHT22 to my new Pi 4 B. I am a complete novice.
I saw a page https://pimylifeup.com/raspberry-pi-hum ... sor-dht22/, that talks about it, but my DHT22 has three pins not four, so I initially connected it up with no breadboard, just the Pi. I then ran some Python on the Pi but just get back "none", "none" as responses.
import Adafruit_DHT
DHT_SENSOR = Adafruit_DHT.DHT22
DHT_PIN = 7
hum, temp = Adafruit_DHT.read_retry(DHT_SENSOR,DHT_PIN)
print ("Humidity is", hum)
print ("Temperature is", temp)
So I then connected it all up to a breadboard, and put a 10k ohm resister between DAT and VCC.
I still don't get anything back other than "none".
I don't think my code is wrong, but have a connected something wrong? I have some photos here.
Also, generally questions, but should I be turning the Pi off everytime I connect/disconnect something, or is that being too cautious?
GregH2O
Re: DHT22 and Raspberry Pi 4 b
Sat May 23, 2020 3:12 pm
Found the problem. I was using the pin number on the board, not the number of the GPIO pin (so I used 7, and should have used 4!).
pcmanbob
Sat May 23, 2020 3:19 pm
Hi.
So looking at your DHT22 board it already had a pull up resistor on the board , so you should only need to connect the following.
VCC to 3.3v pin
GND to ground pin
DAT to the data pin as per the software gpio 4 or physical pin 7
if it still does not work check you don't have the 1-wire interface enabled, run sudo raspi-config interfaces and make sure disabled is selected for 1-wire interface.
As for connecting things to the pi , its advisable to do all connections/disconnections with the pi powered off, and to check you have things connected correctly at least twice before powering pi.
Edit ....... problem solved while I was posting but will leave this up anyway.
GregH2O
Sat May 23, 2020 3:26 pm
Hi pcmanbob,
Thanks for the response.
So I don't need the breadboard?
EDIT: Nope, tried it without, and all good :)
