Destroyer_
Automatic VLC Stream start at Boot/Reboot
Fri Jan 11, 2019 7:21 pm
I have built with an Raspberry Pi a remote Webcam that streams that freed with VLC. I tried before starting the stream with Putty, but the command captures the console/terminal that means if I close the putty window the stream stops.
Stream command:
$ sudo cvlc v4l2:///dev/video0:chroma=h264 cvlc --sout '#standard{access=http,mux=ts,dst=8080}' :demux=h264 --rt-priority
I tried let crontab start a script with the stream command in it.
script:
#!/bin/sh
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
 /etc/init.d/CamStart.sh
exit 0
crontab -e:
@reboot /etc/init.d/CamStart.sh/code]
