Roo_027
Pynput - RC Car and Motors
Sat Jan 20, 2018 6:52 pm
Good evening everyone
I have finished building the body for my RC Car and have attached the 2 motors, battery pack, the raspberry pi, motor board and ultrasonic distance detector.
About 10 days or so ago I requested help with which GPIO pin numbers to assign to the motor terminals - the code for that I have adjusted and the wheels turn fine when I write predetermined seconds for them to turn.
Now I would like to be able to control the movement of the car from my PC keyboard through the WiFi at home - I understand you can do this using Putty which I have installed and will look at later. Right now I would like to know if I can use the Python module "Pynput" to tell the vehicle to move in all directions based on "WASD" keys.
I have tried downloading and installing "Pynput" but when I started writing the code in Python:
from pynput import Key, Controller
I got the following error:
"from pynput import Key, Controller
ImportError: No module named pynput"
I tried downloading/installing the module using the terminal but it is not working. I tried:
"sudo pip install python-pynput"
"sudo apt-get install python-pynput"
Neither of these works. Has anyone used this module in the past for such a project? I know pygame also has the ability to read what key the person has pressed but I am not sure that makes sense to use here.
Thank you in advance!
pcmanbob
Re: Pynput - RC Car and Motors
Sat Jan 20, 2018 9:20 pm
You look to have installed python-pynput for python 2, are you running you program using python3 by any chance.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
Roo_027
Sun Jan 21, 2018 8:59 am
Hi there
Yes I am using Python 2.
pcmanbob
Sun Jan 21, 2018 11:58 am
Looking at the these docs for pynput I think you have you import line wrong.
https://pythonhosted.org/pynput/keyboard.html
from pynput.keyboard import Key, Controller
from pynput.keyboard import Key, Listener
are 2 of the options.
you will have to read the docs to decide which you need to use.
Roo_027
Sat Jan 27, 2018 1:42 pm
Thank you for the reply.
I will go through the docs and work out how to do the "WASD" configuration.
me_xyz
Sun Nov 11, 2018 12:37 pm
install pynput in python3
sudo pip3 install pynput
and, run your code.
