bubby604
Adafruit_PWM_Servo_Driver on Raspian Stretch
Fri Oct 13, 2017 3:16 am
I have a Adafruit 16-Channel 12-bit PWM/Servo HAT (P2327) that is installed on a RPi3. I followed Adafruits directions and it worked perfectly on the Pi with Raspian Jessie. I then decided to upgrade to the latest Raspian Stretch. Everything seemed to install fine. I went to run the test python program "Servo_Example.py" which worked fine on Jessie and nothing happens. No errors, no movement. Any ideas would be appreciated.
MrYsLab
Re: Adafruit_PWM_Servo_Driver on Raspian Stretch
Sat Oct 14, 2017 10:34 pm
Have you enabled i2c with raspi-config after installing stretch?
bubby604
Sun Oct 15, 2017 12:41 am
My apologies, I'm an idiot. The HAT works fine if you plug in the 5v servo power supply. :oops:
OutoftheBOTS
Sun Oct 15, 2017 2:34 am
Ha Ha Ha classic it call out
Who is online
Users browsing this forum: No registered users and 11 guests
