xvi
Live people counting device
Thu Jun 15, 2017 9:28 am
I am new raspberry pi user and i need some advices.
So i want to build a 'live pople counting device' with raspberry pi 3 model B camera or motion sensor (doesnt matter). Also have to connect 2 or more cameras/sensors.
How I can do this?
topguy
Re: Live people counting device
Thu Jun 15, 2017 2:23 pm
How big of an area are you going to monitor ? A singel door/gate or a large room/corridor ?
Can the people move in both directions ?
There is a huge difference between counting people moving through a one-way gate and counting the number of people present in a room.
xvi
Thu Jun 15, 2017 2:32 pm
Its not single door, its a corridor - width: 140cm. lenght: 420cm. I need to count how many people are go in/out.
And, i just need to count how many people moved through the camera/sensor.
Moe
Thu Jun 15, 2017 10:57 pm
Myself and a fellow student actually did this as a uni project, many years ago, before cheap single board computers.
We used three IR beams, one at chest/neck height and two at roughly hip level. The top one did the 'count' and the bottom two determined direction. It was all done with logic gates. It worked, but only when the corridor was so narrow that only one human could pass at a time, which sadly doesn't apply in your case.
Depends on application really. If you need a rough population figure for marketing purposes, then it's quite easy. If you want to know the how many people are in the building for a head count in the event of fire, forget it. Use a turnstile.
Submarine communication systems engineer and amateur robot enthusiast.
xvi
Mon Jun 19, 2017 10:20 pm
I think to use this - https://github.com/WatershedArts/Footfall . Hope it will work.
xvi
Tue Jun 20, 2017 12:02 pm
Someone who have expirience with that? Footfall ^
supra
Fri Jun 23, 2017 2:21 pm
xvi wrote:Hello,
How I can do this?
I merely used OpenCV 3.2.0 and webcam. Unfortunately, I haven't attempted pi-camera yet.
So no need to used sensor anymore The sensor will not work for you. So save your budget :o :o :o :o
xvi
Sun Jul 09, 2017 1:19 pm
I still need help with this. I dont have any experience with raspberry.
Is there any guide or something to help me building device that can count people from live video (purchased raspberrypi camera). And im using raspberry3.
Who is online
Users browsing this forum: No registered users and 19 guests
