sarandaegus
Problem Serial ttyUSB0 code
Sat Dec 17, 2016 4:05 pm
Hi, this is my first post in this comunity, so sorry if the post dont belong here.
ok.i am working in the comunication with raspberry pi with RPLIDAR sensor, The RPLIDAR is a sensor scanner 2D, this send points in the plane.i have tried with this code in python:
https://github.com/jmccormack200/RPLida ... arPrint.py
but it doesnt work, i understand thar i have to change the last code line, because i am working in Debian Software (Linux) and the COM port dont exist, the usb port of the sensor is "/dev/ttyUSB0"
if __name__ == "__main__":
    #COM4 was used on my computer, this will change based on
    #your setup and whether you're on Windows/Mac/Linux
    #port = '/dev/ttyUSB0'
    #port = 20
    port = "/dev/ttyUSB0"
    ser = serial.Serial(port, 115200, timeout = 5)
    ser.setDTR(False)
    print ser.name
    #Create a Lidar instance, this will immidiately start printing.
    #To edit where the data is sent, edit the GetPoints Method
    lidar = Lidar(ser)
when i run this, appears this:
/dev/ttyUSB0
Connecting
the right response when the code is running is this:
./dev/ttyUSB0
Connecting
(146, 131)
(147, 132)
(148, 133)
(150, 134)
(151, 135)
(154, 135)
(156, 137)
(158, 139)
(161, 140)
(164, 141)
(166, 142)
but dont work this, so what is the problem?
In this other forum, they work with this code and it does work.
https://github.com/ev3dev/ev3dev/issues/491
I have to work with the sample code of RPLIDAR and this work in raspberry, so maybe the problem isn't the usb port conection.
pi@raspberrypi:~ $ lsusb
Bus 001 Device 005: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
Bus 001 Device 004: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Thank you and sorry for my english.
Sergio
scruss
Re: Problem Serial ttyUSB0 code
Sun Dec 18, 2016 4:15 am
Is your pi user a member of the dialout group? You need that for serial access. Do this, then log out and back in again:
    sudo usermod -a -G dialout pi
sarandaegus
Sun Dec 18, 2016 10:19 am
Hi Mr.scruss right now i am trying with this code:
pi@raspberrypi:~ $ sudo usermod -a -G dialout pi
pi@raspberrypi:~ $
Not seen nothing .. is it ok? Then i tried to run my code and the same problem appears. What is wrong? :S
Also tried in root mode, but is same, too i tried change ('/dev/ttyUSB0') for ("/dev/ttyUSB0") in my code but the problem persists.
Any other suggestions?
Thank you for you response.
Sergio
sarandaegus
Sun Dec 18, 2016 10:31 am
Ah .. I forgot to tell you that after entering the code, I rebooted raspberry
pi@raspberrypi:~ $ sudo reboot
scruss
Mon Jun 19, 2017 2:55 pm
Is your serial port really /dev/ttyUSB0? The output from dmesg will tell you what the device name is.
Who is online
Users browsing this forum: No registered users and 7 guests
