As said in my previous post, Kalliopé is a vocal assistant that can controll mpd and mopidy (can still be improved), but it does the job.chill07 wrote:i dont know if jasper can control an mpd. i hope it can. i also checked the jasper documentation site but according to some, it has not been updated for a very long time. I really need a voice assistant which can control an mpd.
thank you very much sir. i'll try to use that. is installing it easy? i mean for a beginner like me? as i said i'm pretty much new to this.bacardi55 wrote:As said in my previous post, Kalliopé is a vocal assistant that can controll mpd and mopidy (can still be improved), but it does the job.chill07 wrote:i dont know if jasper can control an mpd. i hope it can. i also checked the jasper documentation site but according to some, it has not been updated for a very long time. I really need a voice assistant which can control an mpd.
Kalliopé website
Kalliopé MPD /Mopidy demo integration (in french with subtitle)
Cheers,
Well, it's relatively easy, but bare in mind that you will to have to open a terminal and run a few commands…chill07 wrote:thank you very much sir. i'll try to use that. is installing it easy? i mean for a beginner like me? as i said i'm pretty much new to this.
Thank you for the reply sir. Last question if you dont mind, is it free?bacardi55 wrote:Well, it's relatively easy, but bare in mind that you will to have to open a terminal and run a few commands…chill07 wrote:thank you very much sir. i'll try to use that. is installing it easy? i mean for a beginner like me? as i said i'm pretty much new to this.
NOrmally a simple pip install should do the trick or the easiest would be to download the rpi image provided.
Feel free as well to go to the gitter chat where someone can help you live
chill07 wrote:Thank you for the reply sir. Last question if you dont mind, is it free?
Users browsing this forum: No registered users and 7 guests
