Hi all,
I've got a raspberry pi running raspbian and i've setup and configured openVPN so i can use my home network when away from home (holiday/work/out in town etc) , the VPN part is working fine - installed apache to be able to work on little test projects, and it's setup and works fine..locally i can access htpp://192.168.0.9 at home or when connected through my VPN
HOWEVER i cant access the web server using frogs.zapto.org (the dynamic dns hostname linked to my dynamic home ip) --- the VPN works using this host name, but apache doesn't
I've checked and there doesn't seem to be any FW rules that would be stopping this? Only rules I have are to do with VPN and masquerading
Checked the config and it all looks fine (and as i say it works locla using 192.168.0.9!!)
I logged into my router and checked, and the port is forwarded but still NOTHING
ssh/VPN both work using the remote host/IP but apache wont!!
ANY suggestions greatly appreciated
thanks
map
