Gert
How to retrieve bind9 statistics
Wed Sep 10, 2014 5:58 am
Hello All,
Following the very nice instructions given here :
https://www.digitalocean.com/community/ ... untu-14-04
I installed a bind9 DNS server on my RPI.
Now I want to see some statistics how efficient the caching works in the DNS server for my home network.
* I want to see the count of DNS data base entries grow i.e. when www surfing
* I want to see how many requests were satisfied from the local cache
* File size growth of the local cache (where is the cache actually?)
How can I get all these infos from the bind9?
Thanks,
Gert
gdt
Re: How to retrieve bind9 statistics
Wed Sep 10, 2014 11:12 am
That's a good guide. Nice find. Add that to the existing Raspbian config (which is quite good at setting up the default zones which even a forwarder should serve rather than recurse).
Not sure why they are forcing IPv4 only. It works fine on my IPv4+IPv6 home network.
Anyways, the answer is in two parts. (1) record stats
options {
  statistics-file "/var/lib/bind/stats";
  zone-statistics yes;
You can also turn on or off zone statistics by zone
zone "localhost" {
  type master;
  file "/etc/bind/db.local";
  zone-statistics no;
(2) analyse stats. You probably just want a simple RRD-based tool like dnsgraph. CollectD also does a good job, but perhaps it's resource demands are a little too much for the RPi.
