Twana94
RaspRack
Wed Jul 16, 2014 1:48 pm
My Raspberry Pi project is called RaspRack. It is a 1U serverunit containing five Raspberry Pi, a networkswitch, an USB-hub and six fans. To power it it need one 12V and one 5V input. It also need a networkcable lto work properly.
On the front there are 5 rectangular holes for SD-cards to be put in, and above each hole there are a green LED. The LED will glow if the raspberry behind it is powered. On each side there are three holes for the fans. The fans on one side sucks in air into the box, and the fans on the other side pushes the air out which create a good airflow trough the RaspRack. The backside of the rack is where power and network come in. There are also five flipswitches for turning on and off the power to each Raspberry Pi. The whole box is painted matte black and on the lid the Raspberry Pi logo is painted in silver.
Ravenous
Re: RaspRack
Wed Jul 16, 2014 2:44 pm
Like the front-accessed SD slots, that's a good idea.
I also like the paint job on the top! :D
norman.santana
Re: RaspRack
Wed Nov 19, 2014 11:28 pm
Hello
Nice Work, I would like to know Where I can Get a Rack Case like yours
Regards
DirkS
Re: RaspRack
Wed Nov 19, 2014 11:40 pm
norman.santana wrote:Hello
Regards
The case a standard unit for a 19"" rack and should be widely available. I think the OP modified a 1U server unit (holes for the SD cards, etc)
http://en.wikipedia.org/wiki/19-inch_rack
http://en.wikipedia.org/wiki/Rack_unit
Gr.
Dirk.
norman.santana
Re: RaspRack
Thu Nov 20, 2014 1:30 am
Thank You Dirk
Can you post the Bill of Materials, Based on the picture the USB Card with a modified cables power up the fans,
drgeoff
Re: RaspRack
Thu Nov 20, 2014 11:47 am
I think 6 fans will be gross overkill.
lpa
Re: RaspRack
Thu Nov 20, 2014 2:19 pm
That really depends on where it's installed if you stuck it in a rack of just these then most likely but if you stuck this in a rack with proper rack servers while the pi's don't kick out alot of heat they do so by having the six fans it helps deal with the excess heat radiating from the surrounding systems
BMS Doug
Re: RaspRack
Thu Nov 20, 2014 3:27 pm
drgeoff wrote:I think 6 fans will be gross overkill.
nope, 144 fans is Gross overkill.
Sorry I couldn't resist.
If you added a 12v to 5v DC to DC converter you could reduce the connections to just the 12v input.
Doug.
Ravenous
Re: RaspRack
Thu Nov 20, 2014 4:23 pm
The OP hasn't come back for a long time folks; just saying, these helpful design hints are probably being ignored ;)
DirkS
Re: RaspRack
Thu Nov 20, 2014 6:35 pm
Ravenous wrote:The OP hasn't come back for a long time folks; just saying, these helpful design hints are probably being ignored ;)
Maybe not for the OP, but maybe useful for the 'resurrector' of this topic. See http://www.raspberrypi.org/forums/viewt ... 58#p643029?
