Installing Vyatta on Pi
Posted: Thu Jun 26, 2014 7:10 pm
by flyer86
Hi
I want to install the vyatta protocol on my raspberry pi version B... I couldnt find any package online for vyatta.... How can i install it? Should i need to put its ISO in SD card and then install it from there?
Regards,
flyer
Re: Installing Vyatta on Pi
Posted: Thu Jun 26, 2014 8:42 pm
by DougieLawson
Does vyatta provide source code or an ARMv6 hard float version? Because if not then you don't have a cat in hell's chance of getting it running on your RPi.
Posted: Fri Jun 27, 2014 4:00 am
by flyer86
hi
thanks for the response.
Actually the thing is i am working on an academic project whose aim is to perform open source routing. First i was using quagga protocol but it doesn't offer much features with routing like QOS, dhcp service, VPN ip sec etc, so i jump to vyatta which has a wide range of features to offer. So i dont know how to find if it provide source code or has ARMv6 hard float version?
flyer
Posted: Fri Jun 27, 2014 4:51 am
by fruitoftheloom
flyer86 wrote:Hi
Regards,
flyer
ARMHF not supported:
Vyatta is now owned by Brocade and closed source, however there is an open source fork VyOS which in wiki states
"VyOS is a fork of the Vyatta CE edition of routing software. VyOS is a Linux based routing solution built on the Debian Linux distribution, and currently runs on i386 and X86_64 bit platforms."
http://en.wikipedia.org/wiki/VyOS
http://vyos.net/wiki/Main_Page
Posted: Sat Jun 28, 2014 4:58 am
by flyer86
So vyos is also not for ARM as it is only for i386 & .x86. Can you suggest me another open source protocol which will give us the same features as of vyatta on pi . i want to make my pi an open source router having VPN, QoS, dhcp server like services available?
fruitoftheloom wrote:flyer86 wrote:Hi
Regards,
flyer
Posted: Sat Jun 28, 2014 8:21 am
by fruitoftheloom
Posted: Sat Jun 28, 2014 10:00 pm
by flyer86
Posted: Sat Jun 28, 2014 10:55 pm
by flyer86
What are the same product in .x86 like like Raspberry PI ARM? Do we have any product available?? sorry for asking in this platform as guys here might have knowledge of same products
Posted: Sat Jun 28, 2014 11:40 pm
by riklaunim
flyer86 wrote:What are the same product in .x86 like like Raspberry PI ARM? Do we have any product available?? sorry for asking in this platform as guys here might have knowledge of same products
Any nettop PC will have similar small size. Intel NUC, Gigabyte Brix, Foxconn Nettops and many more. There are hacker-boards like Minnowboard-Max, but they will cost more than similar Nettop (consumer mass made product). In some cases cheaper/better may be bit bigger mini-ITX classical PCs (you pay extra for something to be smaller). You can check my
Celeron J1900 mini-ITX PC build for an example.
Posted: Mon Jun 30, 2014 11:17 pm
by flyer86
thank you all for your guidance!
