Send Information From SPI through Ethernet
Posted: Thu May 29, 2014 12:14 am
by thorntonatron
I was wondering if it is possible to transfer data received by the SPI through the ethernet on to a PC. I have the SPI working and receiving data Ok and the ethernet is connected by a bridged network to a Windows PC. However, I was looking for information on where to start to transfer the data received by the SPI to a client app on the PC.
Thanks for any help or direction
Re: Send Information From SPI through Ethernet
Posted: Thu May 29, 2014 7:22 am
by DeeJay
My suggestion is that you need to focus on understanding the data transfer mechanism used by the client app on the PC.
Posted: Thu May 29, 2014 4:09 pm
by thorntonatron
I was planning on just developing a relatively simple application using C++. This question was more garnered towards seeing if this was possible. I have initially looked into sockets and how they work as a means of transferring data across.
Posted: Thu May 29, 2014 4:22 pm
by DeeJay
I'm sure that's a possible solution. Or you might be able to remotely run a script via ssh and have the data transferred onto the PC that way. (ssh has more uses than simply performing a remote logon to a system.)
Posted: Fri May 30, 2014 1:38 pm
by thorntonatron
Well I have SSH up and running now so I think what I could do is have my python script run at start-up on the Pi, as it reads in data from the SPI I could devise a program that listens to what is incoming on port 22 and outputs on to the PC screen. I am fairly new to Linux systems so don't know how to fully implement this but thanks for the point in the right direction.
