PHP code commented out on apache server
Posted: Sun Mar 23, 2014 5:59 am
by kevbot
I have followed numerous tutorials on how to setup a basic LAMP server on my Pi running Raspbian Wheezy, and have got the initial 'index.html' to run correctly, and connected from another device on my home network.
Although I have supposedly successfully installed apache2, php5, mysql-server, mysql-client, and php5-mysql, PHP still isn't functioning properly. Any HTML code in a .php file will display - but PHP code is displayed in my browser element inspector as commented out, or other weird stuff. Here is an example. I have a file in my /var/www/ directory called phptest.php, and its content is simply:
When I open the page in-browser, however, it will show as:
<html><head></head><body><pre style="word-wrap: break-word; white-space: pre-wrap;"><?php
phpinfo();
</pre></body></html>
or
Can anyone please help me fix this?
I hope this is the right place to ask, sorry if not.
Thank you for your time.
Re: PHP code commented out on apache server
Posted: Sun Mar 23, 2014 7:16 am
by ripat
Posted: Sun Mar 23, 2014 7:31 am
by rpdom
As php5 pulls in libapache2-mod-php5, you shouldn't need to do the a2enmod manually, but it is worth a try, as is restarting your apache server afterwards.
Your code should work. I just tried it and it did.
Posted: Sun Mar 23, 2014 8:49 am
by kevbot
Hi there, the a2enmod command returned:
ERROR: Module php5 does not exist!
Does this mean it was incorrectly installed?
Posted: Sun Mar 23, 2014 8:59 am
by rpdom
Is libapache2-mod-php5 actually installed? It should be.
You can check with
If you get something that starts with "ii", then it is installed. It should look a bit like this (except I run apache on a PC, not a Pi, so some bits will differ, like it will say 'armhf' instead of 'i386', the rest should be the same)
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii libapache2-mod 5.4.4-14+deb i386 server-side, HTML-embedded script
Posted: Sun Mar 23, 2014 10:14 am
by kevbot
Okay, I tried that and it returned
iU libapache2-mod 5.4.4-14+deb armhf server-side, HTML-embedded script
I'm sorry if I don't pick up on what you're doing, I'm pretty new to the Pi.
Posted: Sun Mar 23, 2014 10:16 am
by DougieLawson
sudo apt-get install libapache2-mod-php5
should fix it.
Posted: Sun Mar 23, 2014 10:22 am
by kevbot
DougieLawson wrote:sudo apt-get install libapache2-mod-php5
should fix it.
Hi, apparently it's already installed to to the newest version...
Posted: Sun Mar 23, 2014 10:23 am
by rpdom
It looks like the install has been requested, but failed for some reason.
The first "i" means "Desired state = Installed".
The "U" means "Current state = Unpacked", which is part way through the install procedure of Download, Unpack, Setup, Install, Configure.
The question is why it failed?
Try sudo apt-get -f install and if it fails post the entire output of the command here.
Posted: Sun Mar 23, 2014 10:36 am
by kevbot
rpdom wrote:It looks like the install has been requested, but failed for some reason.
Okay it's pretty long, but here's what happened
pi@raspberrypi ~ $ sudo apt-get -f install libapache2-mod-php5
Reading package lists... Done
Building dependency tree
libapache2-mod-php5 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 17 not upgraded.
9 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
Setting up mysql-server-5.5 (5.5.35+dfsg-0+wheezy1) ...
[ ok ] Stopping MySQL database server: mysqld.
insserv: warning: script 'mathkernel' missing LSB tags and overrides
insserv: There is a loop between service rpc_shellinaboxd and mathkernel if stopp ed
insserv: loop involving service mathkernel at depth 2
insserv: loop involving service rpc_shellinaboxd at depth 1
insserv: Stopping mathkernel depends on rpc_shellinaboxd and therefore on system facility `$all' which can not be true!
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing mysql-server-5.5 (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up apache2.2-common (2.2.22-13+deb7u1) ...
dpkg: error processing apache2.2-common (--configure):
dpkg: dependency problems prevent configuration of apache2-mpm-prefork:
apache2-mpm-prefork depends on apache2.2-common (= 2.2.22-13+deb7u1); however:
Package apache2.2-common is not configured yet.
dpkg: error processing apache2-mpm-prefork (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of apache2:
apache2 depends on apache2-mpm-worker (= 2.2.22-13+deb7u1) | apache2-mpm-prefork (= 2.2.22-13+deb7u1) | apache2-mpm-event (= 2.2.22-13+deb7u1) | apache2-mpm-itk (= 2.2.22-13+deb7u1); however:
Package apache2-mpm-worker is not installed.
Package apache2-mpm-prefork is not configured yet.
Package apache2-mpm-event is not installed.
Package apache2-mpm-itk is not installed.
apache2 depends on apache2.2-common (= 2.2.22-13+deb7u1); however:
dpkg: error processing apache2 (--configure):
dpkg: dependency problems prevent configuration of libapache2-mod-php5:
libapache2-mod-php5 depends on apache2-mpm-prefork (>> 2.0.52) | apache2-mpm-itk ; however:
libapache2-mod-php5 depends on apache2.2-common; however:
dpkg: error processing libapache2-mod-php5 (--configure):
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.5; however:
Package mysql-server-5.5 is not configured yet.
dpkg: error processing mysql-server (--configure):
dpkg: dependency problems prevent configuration of php5:
php5 depends on libapache2-mod-php5 (>= 5.4.4-14+deb7u8) | libapache2-mod-php5fi lter (>= 5.4.4-14+deb7u8) | php5-cgi (>= 5.4.4-14+deb7u8) | php5-fpm (>= 5.4.4-14 +deb7u8); however:
Package libapache2-mod-php5 is not configured yet.
Package libapache2-mod-php5filter is not installed.
Package php5-cgi is not installed.
Package php5-fpm is not installed.
dpkg: error processing php5 (--configure):
Setting up shellinabox (2.14-1) ...
dpkg: error processing shellinabox (--configure):
Setting up tomcat6 (6.0.35-6+deb7u1) ...
dpkg: error processing tomcat6 (--configure):
Errors were encountered while processing:
mysql-server-5.5
apache2.2-common
apache2-mpm-prefork
apache2
libapache2-mod-php5
mysql-server
php5
shellinabox
tomcat6
E: Sub-process /usr/bin/dpkg returned an error code (1)
Posted: Sun Mar 23, 2014 10:51 am
by rpdom
Ok, thanks for that. The detailed report is exactly what was needed to diagnose this issue.
It looks like mysql can't be configured due to a problem with "mathkernel" which I believe is part of the wolfram maths system that is installed on Raspis by default now. I don't have that package installed (it's too big, has this annoying bug and I don't need it for anything I do). I can't remember the full name of it, but if you can find it, or someone else can prompt with details) and you don't use it, then removing it would be a good idea and free up about 0.5GB of space on your card. If you do need it, I'm sure someone who knows what they are doing can tell you how to edit the start up files for that software so they work correctly.
Then, you should be able to run that apt-get -f install and complete the install of mysql, apache and php
Posted: Sun Mar 23, 2014 2:08 pm
by DougieLawson
sudo apt-get purge wolfram*
gets rid of that mathkernel script and frees up 500MB of space.
Posted: Wed Mar 26, 2014 10:48 am
by kevbot
Thank you so much to everyone, the wolram thingy worked
PHP is working!
