andrewstillie
Port Forwarding
Tue Feb 04, 2014 2:54 pm
Hi there,
I am trying to build a PI gadget that has a webserver + mysql database running on it. It will be connected to a home router and remotely accessed (other nodes sending in mysql quiries).
I would like to operate this so that the user does not have to reconfigure there home router port forwarding setting. Is there any way I can do this?
Thanks in advance
Andy
topguy
Re: Port Forwarding
Tue Feb 04, 2014 3:32 pm
You can use uPnP to trigger a portforwarding in the router, but not all routers have uPnP support and not all users wants to have it enabled. ( some people even have two routers, ISP-router + wifi-router )
Random perl script for uPnP:
http://www.howtoforge.com/administratin ... e-via-upnp
I havent googled for specific languages, it just was the second example I found. (the first was Java)
The other solution is to make a closed VPN with hamachi or similar solution and have the server and all clients talk to eachother via the VPN.
andrewstillie
Re: Port Forwarding
Wed Feb 05, 2014 9:49 am
Much appreciated - I will do some background reading this evening.
