Richard-TX
Re: Send email to raspberry pi to do tasks
Sat Jan 10, 2015 4:52 pm
I will do what I can.
The key to all of it is the .forward file in the recepients home dir.
Pipeing the email into a script from within the .forward file is what is needed.
There are a few examples.
Let me know if you get stuck.
Here is a quick and easy guide.
http://www.activecampaign.com/help/forw ... pe-script/
Richard
Doing Unix since 1985.
Richard-TX
Sat Jan 10, 2015 6:09 pm
I just grabbed a spare pi that I have exim installed on and created a .forward file for the user "pi"
in it says this:
| /home/pi/myscript
then I created a script in pi's home dir that says this:
#!/bin/sh
cat >> /tmp/pi-msg
date >> /tmp/msgdate
Then I made the script executable
chmod 755 /home/pi/myscript
It worked.
Now what you want the script to do is up to you.
a cut and a grep should be all that you need to execute any command.
since exim replaces sendmail you can do the following to see what is happening
/usr/lib/sendmail -v pi
type some stuff
end with a dot on a line all by itself
Richard
