doni49
Exim4 Issue
Wed Jan 29, 2014 12:34 am
I have RasPBX (http://www.raspberry-asterisk.org) loaded on a RasPi.
Exim4 is installed as part of the distro (so that it can send vmail/faxes via email). Part of the instructions I'm reading tell me to enter the following command and an email should arrive in my inbox.
send_test_email doni49@mydomain.com
I don't want exim to contact recipient smtp servers directly because I'm on a dynamic IP address and I know such messages are likely to be dropped. I have a hosted web service with a mail server.
The ONLY email messages the RasPi will be sending will be destined for my own email address. I have a web host account which includes a mail server. I've configured exim to send email via the hosted mail server.
The recipient email address (mine) is on the same server. After running dpkg-reconfigure exim4-config, this is the contents of /etc/exim4/update-exim4.conf.conf
dc_eximconfig_configtype='smarthost'
dc_other_hostnames='RasPBX'
dc_local_interfaces='127.0.0.1'
dc_readhost='mydomain.com'
dc_relay_domains=''
dc_minimaldns='false'
dc_relay_nets=''
dc_smarthost='mail.mydomain.com::26'
CFILEMODE='644'
dc_use_split_config='false'
dc_hide_mailname='true'
dc_mailname_in_oh='true'
dc_localdelivery='mail_spool'
doni49
Re: Exim4 Issue
Fri Jan 31, 2014 11:07 pm
Bump.
doni49
Re: Exim4 Issue
Sun Feb 02, 2014 3:16 am
Any ideas or advice?
Richard-TX
Re: Exim4 Issue
Sun Feb 02, 2014 4:57 am
I would follow the directions at http://www.raspberrypi.org/phpBB3/viewt ... il#p497622
I would change gmail to your own smarthost and see what that does for you.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
