Page 1 of 4
Minecraft Server+Webui Node for Rpi1/2/3
Posted: Sat Jan 11, 2014 5:25 am
by kicker22004
Updated post from the old guide guys, I'll be removing my old videos as they are far outdated. Please use this if you would like to run MineOs-Webui. Also i'll be doing a comparison video between Node/Python for features and Ram usage. Please subscribe for that Video. Thanks again for all those who support me and enjoy my content.
Hi guys i'm back with another test video on the Raspberry Pi3 and Minecraft (I might have a problem :P).
This time it's showcasing just the Raspberry Pi3 and MineOs WebUI.
Please like and subscribe if you liked the video guys.
I WANT TO MAKE IT CLEAR, THIS WEBUI IS NOT MINE & I DIDN'T MAKE IT.
I am simply showing others how to install it on their RPi, the creators are found here.. http://minecraft.codeemo.com/
so if you like it please thank them for their hard work, Also WILL is the Man for support!
Was tested on RPi3 running Dietpi headless.
I look forward to comments on this. Thank you guys (Python images)
If you would rather have the script to just run then do this..
sudo apt-get update
Then run this to get going.
wget -O - http://pastebin.com/raw/v6X3gpbS | tr -d '\r' | sudo bash
This will install java for you if you don't already have it and your all set. Please refer to the video for any questions or leave them here.
https://www.youtube.com/watch?v=IQWlv3jMntw
Please leave feedback. Thank You
Re: Minecraft Server+Webui
Posted: Sat Jan 11, 2014 3:35 pm
by kmaca
Thanks so much for this, great idea!
I'm downloading it now for use with Berry Boot
Posted: Sat Jan 11, 2014 11:28 pm
by kicker22004
Ok the torrent is working here and somewhere in England lol. But i updated OP with dropbox link.
Also for those who decided to join and break the main house to figure out the redstone...next time just ask, saves me the time using a restore. Thank You
Posted: Sun Jan 12, 2014 2:07 am
by kicker22004
Ok i think i found the issue. My torrent was working (in house) but nobody else could get it. It looks like a port issue and now i can download via my phone so it's up now.. Can someone comfirm. i also up'd the upload limit from 50kb (sorry) to the one person who got it. to 500kb. Please seed guys and help me out.
Posted: Mon Jan 13, 2014 7:10 am
by Horrorzilla
Downloaded a few minutes ago - torrent works great here in Pennsylvania, US. Will install it on Wednesday (my next day off of work) and post how it goes. Thanks for your hard work.
Posted: Mon Jan 13, 2014 6:52 pm
by Horrorzilla
Well - tried it out today and it didn't boot. says "unable to determine your tty name(after about 7min of booting). None of the logins work, tried pi and raspberry-root and root, and picraft and 12345.
Posted: Wed Jan 15, 2014 4:53 pm
by kicker22004
That's weird...I tested it prior to upload... bad flash? Can you check md5 I'll get that posted.
Posted: Wed Jan 15, 2014 4:58 pm
by kicker22004
Also you did format your card prior to flashing.. And extracted the 7 rars?
Posted: Thu Jan 16, 2014 5:49 am
by gripninerz
im getting the same error
Posted: Thu Jan 16, 2014 9:04 pm
by kicker22004
Ok i'm going to pull the torrent and see if i can find out what's up. Although i'll post my Script for those with a fresh install of raspbian.
Posted: Sat Jan 18, 2014 3:33 pm
by kmaca
It still says permission denied when I tried to run it as root,
Any ideas?
Posted: Sat Jan 18, 2014 3:38 pm
by DougieLawson
kmaca wrote:It still says permission denied when I tried to run it as root,
Any ideas?
Permission denied on what resource?
Because I'd suspect that was an erroneous message meaning "missing file" or "read only file" or some such condition. You, normally, can't prevent root from writing to 99.9% of files, objects and devices on a Unix system. The 0.1% are a complete exception to all rules and incredibly hard to enforce.
Posted: Sat Jan 18, 2014 4:41 pm
by kmaca
I rebooted and it worked fine!
Web UI works now as well
Posted: Sun Jan 19, 2014 5:15 am
by kicker22004
Sweet thanks for replying, Thought i was losing my mind with the script...i KNEW that worked lol.
Posted: Mon Feb 03, 2014 9:44 pm
by Eloverphx
I have tried the script about three times now and don't seem to be getting anywhere with it. I load a new installation of raspian (the latest version) I follow your instructions and it seems to go off without a hitch. After install and reboot I try to connect using my ip address of the pi and port 8080, my browser just sits and spins. I left it for an hour with nothing changing. What raspian did you use to make your server? Maybe something has changed in the newest edition. Thanks for any help you can give. I'm still new to the linux thing.
After looking at some of the websites out there and looking in my mineos.log and see that it keeps closing down. I will try to post here if anyone is interested in looking into it further.
Posted: Tue Feb 04, 2014 10:58 pm
by kicker22004
Are you using https://yourRpiIp:8080
Also you might have a port issue... But you shouldn't..try opening 8080 on your router for the RPI IP.
Posted: Fri Feb 07, 2014 2:30 am
by marshaln1324
Thanks so much for posting this! I love the WebUI feature and would really like to get a Minecraft server running! But I have been having a difficult time getting the server set up though.
I followed your setup exactly, but I'm not so sure about how to set up my server. I added a profile (the Bukkit recommended one) and I added a server, but when I go to start it I get an error that reads :
rsync: change_dir "/var/games/minecraft/profiles/bukkit-recommended" failed: No such file or directory (2) rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1070) [sender=3.0.9]
I don't know too much about Linux or Raspberry Pi's in general, just the basics. Could you please help me out?
Posted: Fri Feb 07, 2014 7:22 am
by kicker22004
When you created the bukket profile... After selecting it did you hit update and wait for it to download the jar file from the bukket server... It takes a minute. (Depending on your net).. If it's right you should see a check mark next to update. You have to download the jar to make the profile directory. Please post back if that helps.
Posted: Fri Feb 07, 2014 7:26 am
by kicker22004
This may help guide you. If you look at the 4th photo on my Original Post it shows the profile page.. Yours should show the bukket profile you picked... On the right it should have that ok check mark.. If it is an X then hit update and wait for it to change to a √. Could take a bit.
Posted: Fri Feb 07, 2014 7:31 am
by kicker22004
Also I use the spigot server.jar because it played nicely with my raspberry pi on ram. Seems many are still having difficulties so tomorrow I will wipe my RPI and install the latest Raspbian and try my instructions to make sure all is well. Also I'll post any updates (if any) in OP.
Update: i did a clean install of raspbian 2014-1-07 and my install was perfect, Also i made a (long and boring lol) video of the install process for those who might be having issues. Check OP for more info.
Posted: Thu Feb 13, 2014 10:47 am
by kicker22004
Will I see my video is getting some views! That's good news.. So can I get some feedback.. Did it help and has anyone else got this running for them now?
Posted: Tue Feb 25, 2014 7:05 am
by kicker22004
Well guys i'm moving away from my Raspberry Pi for now as i got my new Cubox-i4pro and working on it. Side note that Cubox-i4pro is a beast on hosting minecraft!!. I'll come back to my RPi soon but deciding what i want to make it do now. Thanks all and enjoy this setup....Also i think i'll be updating this script soon to make it faster and easier.
Posted: Wed Feb 26, 2014 11:59 am
by Kangaroo
kicker22004 wrote:Well guys i'm moving away from my Raspberry Pi for now as i got my new Cubox-i4pro and working on it. Side note that Cubox-i4pro is a beast on hosting minecraft!!. I'll come back to my RPi soon but deciding what i want to make it do now. Thanks all and enjoy this setup....Also i think i'll be updating this script soon to make it faster and easier.
Just wondering, what version of Ubuntu do you use?
Also how did you get that Mac OS dock on their?
Nice looking.
Posted: Wed Feb 26, 2014 12:08 pm
by kicker22004
This is Elementary Os 64-bit. It is a Mac clone but very stable.
Posted: Wed Feb 26, 2014 12:35 pm
by kicker22004
Ok before i dig back into this script and change it up and make a new video i have a question.
How many people would like an easier script/automated script?
