dafull97
Mumble Server
Tue Jan 07, 2014 2:48 am
Ok first off im off im not a nubbie, im a little bit more than a normal user...
Problem:
Im trying to host a Mumble server on a Raspberry pi(of course) and i opened the ports on the router, online port checkers register it as open.... that's not the issue the issue is when the server is running it sees it when i conect to it thru local ip address, but when i try the public ip address it don't connect, my ISP is Windsteam Communications.
If you have anymore questions about it Please just ask i am trying to get thios running for a Game Server for minecraft, Thanks!
Dafull97
dafull97
Re: Mumble Server
Tue Jan 07, 2014 3:34 pm
** BUMP I REALLY NEED HELP!**
Thanks,
Daful97 :D
dafull97
Re: Mumble Server
Tue Jan 07, 2014 7:52 pm
ONE LAST Bump, please help :(
Re: Mumble Server
Tue Jan 07, 2014 9:17 pm
Is your Mumble server binding to INADDR_ANY?
Check that with netstat -tln
Does your ISP block any ports (without telling you)?
Have you tried running Apache2 (just the stock install will do) and opening port 80 as a quick & dirty test?
vmp32k
Re: Mumble Server
Wed Jan 08, 2014 3:31 am
Not all routers support NAT loopback, meaning any connections you try to make to your "public" ip from inside the local network will end up on your router without being forwarded.
Try connecting from outside your LAN or ask a friend.
Some routers have an option to enable it, poke around the webinterface if you feel adventurous. ;)
dafull97
Re: Mumble Server
Wed Jan 08, 2014 4:25 am
Dougielawson -- the output
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:64738 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:6502 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:9999 0.0.0.0:* LISTEN
mumble server is on port 9999
Re: Mumble Server
Wed Jan 08, 2014 3:14 pm
Looks good the 0.0.0.0 means it's inaddr_any.
Time to visit Starbucks or McDonalds with a laptop or a tablet.
Or PM your public IP address and I'll try connecting to port 9999.
dafull97
Re: Mumble Server
Wed Jan 08, 2014 9:57 pm
Dougie you have been VERY helpful, i will PM my public ip and see if you can connect and double check my NAT>Virtual Servers
