access point and smb share?
I'm using my rasp version b as a smb share but I got a RTL8188CUS chipset wifi dongle.. so I was wondering if it would really hurt to set it up as a access point as well?
Re: access point and smb share?
anyone? does it have enough ram to act as a smb file host and a access point or do I need to get a second raspberry?
- DougieLawson
- Contact: Website Twitter
The answer, as ever, is "It depends.".ViolentMonk wrote:anyone? does it have enough ram to act as a smb file host and a access point or do I need to get a second raspberry?
What it depends on is a) how much network traffic your samba shares uses b) how much network traffic your access point uses, c) what else is running on that RPi and d) how much you've split it between the GPU and the CPU.
For £35 you could buy a second RPi and have two dedicated servers (one doing SAMBA, the other hostapd).
the raspberry runs headless with a split where most of the ram goes to the cpu. also the access point wont be used the same time as the smb share. when in use only a cell phone/tablet would use the access point and a single raspberry would be using the rasp smb share. oh and the smb rasp is only running smb nothing else.
