achap
network tools?
Thu Nov 14, 2013 10:13 pm
Hi, I wantto use the Raspberry to check the QoS in a LAN. I´m using the raspicam for singlecast HD videostream and a webcam for broadcast HD videostream. My question is: Is there a program that runs on the raspberry that allow me to check the size and the overhead protocol of the packets that are send from the raspberry?
JustThisGuy
Re: network tools?
Fri Nov 15, 2013 12:15 am
If you just want to capture the network packets 'tcpdump' is the tool.
If you want some help with capture and analysis and a display gui then use 'wireshark'.
Any conversation about a sufficiently complex subject is indistinguishable from babble.
achap
Re: network tools?
Sun Nov 17, 2013 10:54 pm
thanks.
I´m already using wireshark. I´ll try tcpdump.
also I read about smokeping. will see which one works for thgre best.
Re: network tools?
Mon Nov 18, 2013 12:06 am
JustThisGuy wrote:If you just want to capture the network packets 'tcpdump' is the tool.
One excellent thing about Wireshark is that it can read a Linux tcpdump and do it's GUI magic with it (on Windows). Formatting a 'tcpdump -w foo.pcap -i eth0' using 'tcpdump -r foo.pcap' becomes redundant. You simply move that foo.pcap file to Windows and Wireshark does it's magic with it.
This is a doctor free zone.
RoyLongbottom
Re: network tools?
Mon Nov 18, 2013 10:35 am
For details of send and receive packets/sec and kB/sec (for average packet sizes), you can install sysstat (sudo apt-get install sysstat), Try it using sar -n DEV 1 10 for 10 samples of 1 second or run such as sar -n DEV 15 32 > sarLAN.txt, for 32 samples of 15 seconds saved to a file.
For CPU loading, try vmstat 1 10 and vmstat 15 32 > vmstatLAN.txt. You might also run the test overclocked at 800 or 900 MHz to better understand overheads.
