marcelp1
Model A + EW-7811Un frequently disconnects
Wed Oct 23, 2013 6:54 pm
Could anyone point me where to look for clues why is it that my
Model A with EW-7811Un disconnects or looses connection to my AP Technicolor TG582n?
My other devices connected to my home AP do not have the disconnect problems ....
I have tried to restart the AP to see if it re-connects, but that does not work
and the only way is the power off/on the Model A and that is not good for
the file system :(
I can think of soft button that would run sudo poweroff or reboot
but still I rather that the connection stays on ;) and find what's the problem.
karlkiste
Re: Model A + EW-7811Un frequently disconnects
Wed Oct 23, 2013 7:37 pm
I had problems that USB pendrives disconnected after a while on model A. It helped to use a USB hub, even a not-powered one. Never saw this on model B. Have you tried with a hub?
MrEngman
Wed Oct 23, 2013 8:31 pm
The following has been a solution for some reporting similar issues.
Make file /etc/modprobe.d/8192cu.conf using command
sudo nano /etc/modprobe.d/8192cu.conf
and insert the two lines into the file
# Disable power management
options 8192cu rtw_power_mgnt=0 rtw_enusbss=0
The driver for the EW7811Un has some power management enabled and that file disables it.
Reboot after making the file.
MrEngman
marcelp1
Fri Jan 24, 2014 5:28 pm
Thank you very much, this seems to solve the problem.
However, should I restart my Access Point to which the RPi is connected to
I would have to pull the plug on power as the RPi would not reconnect to AP automatically :(
Here is my setup:
sudo nano /etc/network/interfaces
auto lo
iface lo inet loopback
#auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.1.2
netmask 255.255.255.0
gateway 192.168.1.1
network 192.168.1.0
broadcast 192.168.1.255
metric 10
wpa-conf /etc/wpa.conf
sudo nano /etc/wpa.conf
network={
ssid="SKY12345"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
psk="passphrase"
Is there anything to be done, once the RPi becomes disconnected, it will try to re-connect
insted of me pulling the power plug to restart it?
Fri Jan 24, 2014 11:45 pm
Get rid of network, broadcast and metric from /e*/n*/interfaces (those things aren't needed).
My Edimax reconnects to my AP and my router if I restart either of those boxes.
This is a doctor free zone.
