pptp very bad performance for browsing
Posted: Sat Sep 07, 2013 12:09 pm
by honda4life
I've tried to set up a VPN-server for someone's business trips.
Because too much normal things are blocked now.
I did a dual config with PPTP and OpenVPN
PPTP works very slow on my own computer and his computer.
OpenVPN works great on my computer, but there is still a problem on his computer (all tested over a remote internet connection). This is another problem i'm working on.
Can someone share his working configuration files, that have been tested good performance.
Here are my config files:
# $Id$
# Sample Poptop configuration file /etc/pptpd.conf
# Changes are effective when pptpd is restarted.
# TAG: ppp
#	Path to the pppd program, default '/usr/sbin/pppd' on Linux
#ppp /usr/sbin/pppd
# TAG: option
#	Specifies the location of the PPP options file.
#	By default PPP looks in '/etc/ppp/options'
option /etc/ppp/pptpd-options
# TAG: debug
#	Turns on (more) debugging to syslog
#debug
# TAG: stimeout
#	Specifies timeout (in seconds) on starting ctrl connection
# stimeout 10
# TAG: noipparam
#       Suppress the passing of the client's IP address to PPP, which is
#       done by default otherwise.
#noipparam
# TAG: logwtmp
#	Use wtmp(5) to record client connections and disconnections.
logwtmp
# TAG: bcrelay <if>
#	Turns on broadcast relay to clients from interface <if>
#bcrelay eth1
# TAG: localip
# TAG: remoteip
#	Specifies the local and remote IP address ranges.
#       Any addresses work as long as the local machine takes care of the
#       routing.  But if you want to use MS-Windows networking, you should
#       use IP addresses out of the LAN address space and use the proxyarp
#       option in the pppd options file, or run bcrelay.
#	You can specify single IP addresses seperated by commas or you can
#	specify ranges, or both. For example:
#		192.168.0.234,192.168.0.245-249,192.168.0.254
#	IMPORTANT RESTRICTIONS:
#	1. No spaces are permitted between commas or within addresses.
#	2. If you give more IP addresses than MAX_CONNECTIONS, it will
#	   start at the beginning of the list and go until it gets
#	   MAX_CONNECTIONS IPs. Others will be ignored.
#	3. No shortcuts in ranges! ie. 234-8 does not mean 234 to 238,
#	   you must type 234-238 if you mean this.
#	4. If you give a single localIP, that's ok - all local IPs will
#	   be set to the given one. You MUST still give at least one remote
#	   IP for each simultaneous client.
# (Recommended)
localip 192.168.0.1
remoteip 192.168.0.234-238,192.168.0.245
# or
#localip 192.168.0.234-238,192.168.0.245
#remoteip 192.168.1.234-238,192.168.1.245
# $Id$
# Sample Poptop PPP options file /etc/ppp/pptpd-options
# Options used by PPP when a connection arrives from a client.
# This file is pointed to by /etc/pptpd.conf option keyword.
# Changes are effective on the next connection.  See "man pppd".
# You are expected to change this file to suit your system.  As
# packaged, it requires PPP 2.4.2 and the kernel MPPE module.
# Authentication
# Name of the local system for authentication purposes
# (must match the second field in /etc/ppp/chap-secrets entries)
name pptpd
# Optional: domain name to use for authentication
# domain mydomain.net
# Strip the domain prefix from the username before authentication.
# (applies if you use pppd with chapms-strip-domain patch)
#chapms-strip-domain
# Encryption
# Debian: on systems with a kernel built with the package
# kernel-patch-mppe >= 2.4.2 and using ppp >= 2.4.2, ...
refuse-pap
refuse-chap
refuse-mschap
# Require the peer to authenticate itself using MS-CHAPv2 [Microsoft
# Challenge Handshake Authentication Protocol, Version 2] authentication.
require-mschap-v2
# Require MPPE 128-bit encryption
# (note that MPPE requires the use of MSCHAP-V2 during authentication)
require-mppe-128
# Network and Routing
# If pppd is acting as a server for Microsoft Windows clients, this
# option allows pppd to supply one or two DNS (Domain Name Server)
# addresses to the clients.  The first instance of this option
# specifies the primary DNS address; the second instance (if given)
# specifies the secondary DNS address.
# Attention! This information may not be taken into account by a Windows
# client. See KB311218 in Microsoft's knowledge base for more information.
ms-dns 192.168.0.1
#ms-dns 10.0.0.2
# If pppd is acting as a server for Microsoft Windows or "Samba"
# clients, this option allows pppd to supply one or two WINS (Windows
# Internet Name Services) server addresses to the clients.  The first
# instance of this option specifies the primary WINS address; the
# second instance (if given) specifies the secondary WINS address.
#ms-wins 10.0.0.3
#ms-wins 10.0.0.4
# Add an entry to this system's ARP [Address Resolution Protocol]
# table with the IP address of the peer and the Ethernet address of this
# system.  This will have the effect of making the peer appear to other
# systems to be on the local ethernet.
# (you do not need this if your PPTP server is responsible for routing
# packets to the clients -- James Cameron)
proxyarp
# Debian: do not replace the default route
nodefaultroute
# Logging
# Enable connection debugging facilities.
# (see your syslog configuration for where pppd sends to)
debug
# Print out all the option values which have been set.
# (often requested by mailing list to verify options)
#dump
# Miscellaneous
# Create a UUCP-style lock file for the pseudo-tty to ensure exclusive
# access.
lock
nobsdcomp
nodeflate
novj
novjccomp
noipx
noauth
mtu 1490
mru 1490
Is it possible to have bad performance due to bad rules in iptables?
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
-A FORWARD -i eth0 -o tun0 -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -s 10.8.0.0/24 -o eth0 -j ACCEPT
COMMIT
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
-A POSTROUTING -o eth0 -j MASQUERADE
-A POSTROUTING -o ppp+ -j MASQUERADE
-A POSTROUTING -s 10.8.0.0/24 -o eth0 -j MASQUERADE
COMMIT
Edit:
Download speed = Upload speed > OK
Resolving pages is still very slow, speedtest doesn't work, yourtube either,...
