dirksoccer
Raspberry pi DHCP server
Mon Aug 26, 2013 11:50 pm
I have been following this guide
http://learn.adafruit.com/setting-up-a- ... l-software
to set up my Pi as a wireless router/access point (it is also acting as a NAS/UPnP server). Hostapd starts fine, and I've double checked that I've followed the steps correctly (caught a few typos), but I'm still getting errors when I try to launch the isc-dhcp-server service. Here is a copy of the syslog error...
Wrote 0 leases to leases file.
Aug 26 14:34:25 raspberrypi dhcpd:
Aug 26 14:34:25 raspberrypi dhcpd: No subnet declaration for eth0 (192.168.1.10).
Aug 26 14:34:25 raspberrypi dhcpd: ** Ignoring requests on eth0.  If this is not what
Aug 26 14:34:25 raspberrypi dhcpd:    you want, please write a subnet declaration
Aug 26 14:34:25 raspberrypi dhcpd:    in your dhcpd.conf file for the network segment
Aug 26 14:34:25 raspberrypi dhcpd:    to which interface eth0 is attached. **
Aug 26 14:34:25 raspberrypi dhcpd: Not configured to listen on any interfaces!
Aug 26 14:47:52 raspberrypi ntpd[2205]: Listen normally on 3 wlan0 192.168.42.1 UDP 123
Aug 26 14:47:52 raspberrypi ntpd[2205]: peers refreshed
Aug 26 14:59:45 raspberrypi kernel: [321545.035060] ip_tables: (C) 2000-2006 Netfilter Core Team
Aug 26 14:59:45 raspberrypi kernel: [321545.067062] nf_conntrack version 0.5.0 (7012 buckets, 28048 max)
Aug 26 15:03:18 raspberrypi udhcpd[7588]: udhcpd (v1.20.2) started
Aug 26 15:03:18 raspberrypi udhcpd[7588]: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
Aug 26 15:17:01 raspberrypi /USR/SBIN/CRON[7653]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Aug 26 15:17:19 raspberrypi kernel: imklog 5.8.11, log source = /proc/kmsg started.
Aug 26 15:17:19 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="2018" x-info="http://www.rsyslog.com"] start
and here is my dhcpd.conf file
# Sample configuration file for ISC dhcpd for Debian
# The ddns-updates-style parameter controls whether or not the server will
# attempt to do a DNS update when a lease is confirmed. We default to the
# behavior of the version 2 packages ('none', since DHCP v2 didn't
# have support for DDNS.)
ddns-update-style none;
# option definitions common to all supported networks...
#option domain-name "example.org";
#option domain-name-servers ns1.example.org, ns2.example.org;
default-lease-time 600;
max-lease-time 7200;
# If this DHCP server is the official DHCP server for the local
# network, the authoritative directive should be uncommented.
authoritative;
# Use this to send dhcp log messages to a different log file (you also
# have to hack syslog.conf to complete the redirection).
log-facility local7;
# No service will be given on this subnet, but declaring it helps the
# DHCP server to understand the network topology.
#subnet 10.152.187.0 netmask 255.255.255.0 {
# This is a very basic subnet declaration.
#subnet 10.254.239.0 netmask 255.255.255.224 {
#  range 10.254.239.10 10.254.239.20;
#  option routers rtr-239-0-1.example.org, rtr-239-0-2.example.org;
# This declaration allows BOOTP clients to get dynamic addresses,
# which we don't really recommend.
#subnet 10.254.239.32 netmask 255.255.255.224 {
#  range dynamic-bootp 10.254.239.40 10.254.239.60;
#  option broadcast-address 10.254.239.31;
#  option routers rtr-239-32-1.example.org;
# A slightly different configuration for an internal subnet.
#subnet 10.5.5.0 netmask 255.255.255.224 {
#  range 10.5.5.26 10.5.5.30;
#  option domain-name-servers ns1.internal.example.org;
#  option domain-name "internal.example.org";
#  option routers 10.5.5.1;
#  option broadcast-address 10.5.5.31;
#  default-lease-time 600;
#  max-lease-time 7200;
# Hosts which require special configuration options can be listed in
# host statements.   If no address is specified, the address will be
# allocated dynamically (if possible), but the host-specific information
# will still come from the host declaration.
#host passacaglia {
#  hardware ethernet 0:0:c0:5d:bd:95;
#  filename "vmunix.passacaglia";
# Fixed IP addresses can also be specified for hosts.   These addresses
# should not also be listed as being available for dynamic assignment.
# Hosts for which fixed IP addresses have been specified can boot using
# BOOTP or DHCP.   Hosts for which no fixed address is specified can only
# be booted with DHCP, unless there is an address range on the subnet
# to which a BOOTP client is connected which has the dynamic-bootp flag
# set.
#host fantasia {
#  hardware ethernet 08:00:07:26:c0:a5;
#  fixed-address fantasia.fugue.com;
# You can declare a class of clients and then do address allocation
# based on that.   The example below shows a case where all clients
# in a certain class get addresses on the 10.17.224/24 subnet, and all
# other clients get addresses on the 10.0.29/24 subnet.
#class "foo" {
#  match if substring (option vendor-class-identifier, 0, 4) = "SUNW";
#shared-network 224-29 {
#  subnet 10.17.224.0 netmask 255.255.255.0 {
#    option routers rtr-224.example.org;
#  subnet 10.0.29.0 netmask 255.255.255.0 {
#    option routers rtr-29.example.org;
#  pool {
#    allow members of "foo";
#    range 10.17.224.10 10.17.224.250;
#  pool {
#    deny members of "foo";
#    range 10.0.29.10 10.0.29.230;
subnet 192.168.42.0 netmask 255.255.255.0 {
range 192.168.42.10 192.168.42.50;
option broadcast-address 192.168.42.255;
option routers 192.168.42.1;
option domain-name "local";
option domain-name-servers 8.8.8.8, 8.8.4.4;
The only other relevant thing I can think of is that my Pi is currently receiving a static IP from my router via LAN because of the way my samba shares are set up.
Any help would be awesome!!
JustThisGuy
Re: Raspberry pi DHCP server
Tue Aug 27, 2013 12:21 am
Since you are trying to set up 'isc-dhcp-server' which runs as 'dhcpd' you should probably stop 'udhcpd' from starting.
Beyond that it appears that dhcpd isn't recognizing your wlan0 subnet. Off the top of my head, check /etc/network/interfaces points wlan0 to dhcp correctly.
Any conversation about a sufficiently complex subject is indistinguishable from babble.
dirksoccer
Tue Aug 27, 2013 1:03 am
Not sure what exactly you mean in the first part? I have no clue what that service is but I assumed it was part of the dhcp server since that is the log I get when I run
sudo service isc-dhcp-server start
As for the second part here is my /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
#wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
#iface default inet dhcp
iface wlan0 inet static
        adress 192.168.42.1
up iptables-restore < /etc/iptables.ipv4.nat
SirLagz
Tue Aug 27, 2013 2:49 am
What does ifconfig -a output ?
dirksoccer
Tue Aug 27, 2013 3:14 am
eth0      Link encap:Ethernet  HWaddr b8:27:eb:3e:73:ae
          inet addr:192.168.1.10  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:27982 errors:0 dropped:0 overruns:0 frame:0
          TX packets:41641 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:2559187 (2.4 MiB)  TX bytes:56598887 (53.9 MiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:34 errors:0 dropped:0 overruns:0 frame:0
          TX packets:34 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1700 (1.6 KiB)  TX bytes:1700 (1.6 KiB)
wlan0     Link encap:Ethernet  HWaddr c4:3d:c7:77:7e:d3
          RX packets:0 errors:0 dropped:28004 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
SirLagz
Tue Aug 27, 2013 4:01 am
wlan0 doesn't have an IP Address, so it won't be able to hand out any IP addresses.
disable ifplugd for wlan0 and try again
dirksoccer
Tue Aug 27, 2013 5:15 am
Any chance you could walk me through that? I'm really new to linux
SirLagz
Tue Aug 27, 2013 5:29 am
http://sirlagz.net/2013/02/10/how-to-us ... r-part-3b/
Follow my blog post there and restart ifplugd afterwards by running /etc/init.d/ifplugd restart
dirksoccer
Wed Aug 28, 2013 2:56 am
Didn't work...
Although I am getting a slightly different syslog error now,
Aug 27 21:50:30 raspberrypi dhclient: DHCPREQUEST on eth0 to 192.168.1.1 port 67
Aug 27 21:50:30 raspberrypi dhclient: DHCPNAK from 192.168.1.1
Aug 27 21:50:30 raspberrypi dhclient: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 7
Aug 27 21:50:30 raspberrypi dhclient: DHCPREQUEST on eth0 to 255.255.255.255 port 67
Aug 27 21:50:30 raspberrypi dhclient: DHCPOFFER from 192.168.1.1
Aug 27 21:50:30 raspberrypi dhclient: DHCPACK from 192.168.1.1
Aug 27 21:50:31 raspberrypi dhclient: bound to 192.168.1.10 -- renewal in 38215 seconds.
Aug 27 21:52:26 raspberrypi dhcpd: Internet Systems Consortium DHCP Server 4.2.2
Aug 27 21:52:26 raspberrypi dhcpd: Copyright 2004-2011 Internet Systems Consortium.
Aug 27 21:52:26 raspberrypi dhcpd: All rights reserved.
Aug 27 21:52:26 raspberrypi dhcpd: For info, please visit https://www.isc.org/software/dhcp/
Aug 27 21:52:26 raspberrypi dhcpd: Wrote 0 leases to leases file.
Aug 27 21:52:26 raspberrypi dhcpd: No subnet declaration for wlan0 (no IPv4 addresses).
Aug 27 21:52:26 raspberrypi dhcpd: ** Ignoring requests on wlan0.  If this is not what
Aug 27 21:52:26 raspberrypi dhcpd:    you want, please write a subnet declaration
Aug 27 21:52:26 raspberrypi dhcpd:    in your dhcpd.conf file for the network segment
Aug 27 21:52:26 raspberrypi dhcpd:    to which interface wlan0 is attached. **
Aug 27 21:52:26 raspberrypi dhcpd: Not configured to listen on any interfaces!
Also, Thanks for all the help/advice guys!
SirLagz
Wed Aug 28, 2013 3:09 am
Can you paste the contents of /etc/default/isc-dhcp-server
dirksoccer
Wed Aug 28, 2013 5:50 pm
# Defaults for isc-dhcp-server initscript
# sourced by /etc/init.d/isc-dhcp-server
# installed at /etc/default/isc-dhcp-server by the maintainer scripts
# This is a POSIX shell fragment
# Path to dhcpd's config file (default: /etc/dhcp/dhcpd.conf).
#DHCPD_CONF=/etc/dhcp/dhcpd.conf
# Path to dhcpd's PID file (default: /var/run/dhcpd.pid).
#DHCPD_PID=/var/run/dhcpd.pid
# Additional options to start dhcpd with.
#       Don't use options -cf or -pf here; use DHCPD_CONF/ DHCPD_PID instead
#OPTIONS=""
# On what interfaces should the DHCP server (dhcpd) serve DHCP requests?
#       Separate multiple interfaces with spaces, e.g. "eth0 eth1".
INTERFACES="wlan0"
SirLagz
Thu Aug 29, 2013 2:40 am
And also ifconfig again please.
Sorry forgot to mention ifconfig.
subbustrato
Thu Aug 29, 2013 1:54 pm
"udhcpd.leases" seems to be absent, could you verify if is present in /var/lib/misc/ ?
dirksoccer
Thu Aug 29, 2013 5:27 pm
Here is my ifconfig output
          RX packets:63796 errors:0 dropped:0 overruns:0 frame:0
          TX packets:21768 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:11708671 (11.1 MiB)  TX bytes:9171396 (8.7 MiB)
          RX packets:460 errors:0 dropped:0 overruns:0 frame:0
          TX packets:460 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:23704 (23.1 KiB)  TX bytes:23704 (23.1 KiB)
          RX packets:679 errors:0 dropped:250771 overruns:0 frame:0
          TX packets:183 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:123912 (121.0 KiB)  TX bytes:48410 (47.2 KiB)
How exactly do I verify the leases file exists??
subbustrato
Thu Aug 29, 2013 7:23 pm
you should go to dir /var/lib/misc/, and verify if there is the file udhcpd.leases, if there isn't create it and restart dhcp.
dirksoccer
Thu Aug 29, 2013 7:30 pm
It appears that udhcpd.leases does exist
(just to make sure I'm doing this right, I ran
cd /var/lib/misc
then the ls command and it spit out udhcpd.leases as the only output)
subbustrato
Thu Aug 29, 2013 7:45 pm
ok, create it empty:
sudo nano udhcpd.leases
then save the file and reboot
dirksoccer
Fri Aug 30, 2013 12:15 am
...didn't work...
I got the same error/syslog as before (wrote 0 leases, wlan0 issues, not configured to listen...see above for full copy/paste)
Thanks for the help guys, we're bound to figure it out soon!
SirLagz
Fri Aug 30, 2013 1:47 am
dirksoccer wrote:...didn't work...
wlan0 still has no IP address...
can you run "ps aux | grep ifplugd" and paste the output
dirksoccer
Fri Aug 30, 2013 2:25 am
Hopefully I ran it right, here's the output I got
root      1717  0.0  0.1   1744   504 ?        S    19:11   0:03 /usr/sbin/ifplugd -i eth0 -q -f -u0 -d10 -w -I
pi        2553  0.0  0.1   3544   868 pts/0    S+   21:24   0:00 grep --color=au            to ifplugd
SirLagz
Fri Aug 30, 2013 8:01 am
Yes, you ran it right.
Can you run ifdown wlan0 && ifup wlan0 and then run ifconfig again and paste the results ?
dirksoccer
Fri Aug 30, 2013 2:50 pm
I ran them both and ifconfig, but got weird outputs for ifdown and ifup, take a look
[email protected] ~ $ ifdown wlan0
ifdown: failed to open statefile /run/network/ifstate: Permission denied
[email protected] ~ $ sudo ifdown wlan0
ifdown: interface wlan0 not configured
[email protected] ~ $ sudo ifup wlan0
Missing required variable: address
Missing required configuration variables for interface wlan0/inet.
Failed to bring up wlan0.
[email protected] ~ $ ifconfig
          RX packets:27117 errors:0 dropped:0 overruns:0 frame:0
          TX packets:9132 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:5548075 (5.2 MiB)  TX bytes:3685655 (3.5 MiB)
          RX packets:140 errors:0 dropped:0 overruns:0 frame:0
          TX packets:140 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:7000 (6.8 KiB)  TX bytes:7000 (6.8 KiB)
          RX packets:0 errors:0 dropped:94685 overruns:0 frame:0
bqaggie2006
Fri Aug 30, 2013 4:07 pm
Not sure if this is it, but it looks like "Address" is missing a "d" in the declaration for wlan0 in your /etc/network/interfaces file. Try fixing that and then issue the following command:
sudo service networking restart
Then run
sudo ifconfig -a
to see if wlan0 has gotten an address yet.
Desktop
Intel Core 2 Duo e8400 3.0 GHz
4 GB RAM - 250 GB System - 1.5 TB Data
Xubuntu 12.10
Raspberry Pi
2 x Model B 512 MB RAM
RaspBMC
dirksoccer
Fri Aug 30, 2013 7:01 pm
......I'm an idiot. That worked, it fixed it, rebooted the pi and the server started up perfectly. Days of troubleshooting because I can't spell address...such is programming I guess LoL.
Anyway, self-deprecating rant over now. Thanks a ton for all the help guys!! The pi is now successfully a NAS/DLNA server that also broadcasts wifi, and just in time for college (I move in tomorrow, and the security measures on their network are the whole reason I'm setting this up). Anyway, thanks a ton!
Who is online
Users browsing this forum: Baidu [Spider] and 15 guests
