mdperry
RPi vs. DNS-323
Wed Jul 31, 2013 2:45 am
I was bored so I decided to see how my RPi configured as a NAS compared to my Dlink DNS-323 I have on my home network.
I used a freeware utility called Lan Speed Test (Lite) v1.3.0 to do the benchmarks and ran the tests from the same PC with under the same conditions.
My DNS-323 has a 500mhz ARM processor and 64MB RAM with two 1 TB disks in a RAID 1 configuration.
My Pi Rev B is running the latest version of Raspbian. It is connected to an external USB hard disk (a 500 GB sata drive in a USB enclosure) and I configured it per the instructions found here: http://www.howtogeek.com/139433/how-to- ... ge-device/
Here are my results and as you can see, under my limited test, the Pi performed better than my NAS. Of course I do not have the RAID redundancy of my NAS setup but interesting nonetheless.
System      File Size(MB)   Write Speed(Mbps)   Read Speed(Mbps)
RPi         1               76.820616           61.244736
RPi         5               82.974808           66.185808
RPi         10              83.648512           66.036512
RPi         20              79.537840           60.807440
RPi         50              81.547416           64.165184
RPi         100             77.865360           64.834720
RPi         500             81.555128           56.302984
Average(Mbps)               80.564240           62.796769
DNS-323     1               47.254840           78.095080
DNS-324     5               75.027704           78.425888
DNS-325     10              73.102152           78.584784
DNS-326     20              69.782784           48.863744
DNS-327     50              68.795768           34.267576
DNS-328     100             67.718984           40.798608
DNS-329     500             67.705960           51.314896
Average(Mbps)               67.055456           58.621510
SirLagz
Re: RPi vs. DNS-323
Wed Jul 31, 2013 2:52 am
RAID1 will make a difference to write speeds as the NAS has to write the same data twice.
You could also setup software RAID on the Pi and see how that goes :D
My Blog - http://www.sirlagz.net
Visit my blog for Tips, Tricks, Guides and More !
WiFi Issues ? Have a look at this post ! http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=44044
