Wifi USB dongle doesn't like new power pack
Posted: Wed Jul 03, 2013 4:45 pm
by ZacharyI123
I have an Edimax EW-7811UN 150Mbps Wireless Nano USB Adapter and have used it with my pi for a long time. It works very well and I am very happy with it. That is when I am using the raspberry pi with it and the raspberry pi is plugged into a blackberry micro usb charger (5V, 700mA) that it plugged into the mains. For my next pi project, the pi must move around a garden, therefore cannot be plugged into the mains. I decided to buy a power pack on amazon. I found JZK 20000mah Power bank External Battery Pack (http://www.amazon.co.uk/gp/product/B00C ... UTF8&psc=1). Apparently Port 1 is perfect for the raspberry pi because it outputs 5V at 1000mA. I have tried multiple micro usb to usb cables in this port connected to my pi. The pi works fine with all of them. But whenever I have my edimax wifi usb dongle plugged in, the pi refuses to work, it starts up and during that process, it comes up with an error. I took a picture of the error and will attached it. Does anyone have a solution?
Re: Wifi USB dongle doesn't like new power pack
Posted: Wed Jul 03, 2013 4:47 pm
by ZacharyI123
Posted: Wed Jul 03, 2013 5:04 pm
by joan
That kind of suggests that the powerpack can't supply enough power for the Pi and your wifi dongle. I'm not sure what other conclusion could be drawn.
Posted: Wed Jul 03, 2013 5:55 pm
by ZacharyI123
joan wrote:That kind of suggests that the powerpack can't supply enough power for the Pi and your wifi dongle. I'm not sure what other conclusion could be drawn.
But I have increased the power ?!?!?!? :?
Would it be too risky to try the other port on the power pack (because it has more power)? Should I try fully charging or discharging the power pack? Does anyone have any other ideas?
Posted: Wed Jul 03, 2013 6:41 pm
by ZacharyI123
Is there anything I can do? Is anyone else experiencing it? How did you solve it? Is the battery pack dodgy?
Posted: Wed Jul 03, 2013 6:47 pm
by jackokring
Thicker wire, lower impedance batteries. And mAh is not mA.
by ZacharyI123
From what I read here: http://www.raspberrypi.org/phpBB3/viewt ... 2&p=354962
I have decided to reinstall NOOBSon the SD and boot straight from the battery pack (after charging it to full).
I will post what happens...
Posted: Wed Jul 03, 2013 6:48 pm
by ZacharyI123
jackokring wrote:Thicker wire, lower impedance batteries. And mAh is not mA.
I bought everything off amazon. It does not take batteries, you charge it. Sorry about the mAh mA mistake. What needs thicker wire?
Posted: Wed Jul 03, 2013 8:00 pm
by ZacharyI123
I installed a clean copy of raspbian wheezy onto the SD card, plugged the pi into an HDMI cable that is connect to a TV that has previously worked with the pi, connected to the edimax and keyboard via usb. I made it to the configuration screen and nothing happens when I press the keyboard and the edimax shows no lights. What is wrong with the power block?
Posted: Wed Jul 03, 2013 8:04 pm
by ZacharyI123
ZacharyI123 wrote:I installed a clean copy of raspbian wheezy onto the SD card, plugged the pi into an HDMI cable that is connect to a TV that has previously worked with the pi, connected to the edimax and keyboard via usb. I made it to the configuration screen and nothing happens when I press the keyboard and the edimax shows no lights. What is wrong with the power block?
Should I return it?
Posted: Wed Jul 03, 2013 8:44 pm
by joan
Did you charge it for 20 hours?
Posted: Thu Jul 04, 2013 6:21 am
by ZacharyI123
joan wrote:Did you charge it for 20 hours?
Yes. I cannot use an ammeter or volt meter to check if they are what they are supposed to be because it outputs via USB.
Posted: Thu Jul 04, 2013 6:33 am
by PiGraham
The chances are that the output voltage is a bit low. You can measure the supply voltage at test points on the Pi board.
Always measure a new power device before you connect it.
I have a battery pack sold as suitable for charging phones via USB, but it outputs 4.2 V. It will charge my phone but it won't run my Pi.
Posted: Thu Jul 04, 2013 6:43 am
by ZacharyI123
Where are the test points? Do I just hook my voltmeter up with them?
Posted: Thu Jul 04, 2013 10:41 am
by AndyD
ZacharyI123 wrote:Where are the test points? Do I just hook my voltmeter up with them?
Have a look here.
