Sloppy Webcam
Posted: Sat May 18, 2013 2:59 pm
by davef21370
I have a simple webcam set up over my home network. It uses a Python script to take an image every few seconds and save it to the relevant folder which all works fine. My problem is with the HTML to update the image....
<html>
	<head>
		<title>
			Webcam
		</title>
		<meta http-equiv='refresh' content='3'; url='index.html'>
	</head>
	<body>
		<div align='center'>
			<img src="image.jpg">
		</div>
	</body>
</html>
This forces the browser to update the entire page every 3 seconds which is a bit rubbish to say the least.
What would be a more elegant solution? (I'm fine with coding but new to php, java, etc.)
Any help would be great.
Dave.
Re: Sloppy Webcam
Posted: Wed May 29, 2013 3:13 pm
by SirLagz
Do you know about https://en.wikipedia.org/wiki/Ajax_(programming) AJAX?
Also, jQuery.
http://jquery.com
There are 2 starting points.
Essentially, you need to code it up so jQuery uses ajax to update the image only.
Re: Sloppy Webcam
Posted: Wed May 29, 2013 5:21 pm
by davef21370
Thanks for the reply, I did a quick search based on AJAX and ended up with a JavaScript example here http://www.tek-tips.com/viewthread.cfm?qid=1546531
Cheers.
Dave.
