Bus error
Posted: Sat May 04, 2013 6:33 am
by Powerphil
Morning everyone,
I am trying to edit the minidlna conf file in nano, but when I try to start nano, I get a "bus error" and nano fails to start. Everything else is ok. Any ideas?
Re: Bus error
Posted: Sat May 04, 2013 7:01 am
by DeeJay
Powerphil wrote:Everything else is ok. Any ideas?
Does that mean that nano can open and edit other files? Or is running nano not possible at all?
What operating system do you have installed?
Re: Bus error
Posted: Sat May 04, 2013 7:26 am
by Powerphil
Hi, nano isn't working at all. I've tried to remove it and reinstall, but I'm getting various errors as well. I've also noticed the VPN is down, which I think us attributable also to this issue.
To be honest, I'm going to reimage and start again.
Image is wheezy
Re: Bus error
Posted: Sat May 04, 2013 8:20 am
by DeeJay
Powerphil wrote: I'm going to reimage and start again.
Image is wheezy
If you haven't invested too much effort in customising your system that is probably a sound idea.
nano has always worked 'out of the box' for me
If you've added other packages to your system, I wonder if you have a storage space issue? Did you use the expand_rootfs option in raspi-config to take advantage of all the space on the SD card?
Good luck with your fresh start.
