pishark
Hamachi on Pi?
Mon Apr 22, 2013 6:46 pm
I was just wondering if it would be possible to access private networks on the Raspberry Pi using a program like Hamachi.
P.S. The Raspberry Pi rocks!!! :)
pi5149
Re: Hamachi on Pi?
Tue Apr 23, 2013 12:47 am
try this page. It takes long time to setup, hope it works fine for you.
http://lifehacker.com/5978098/turn-a-ra ... ere-you-go
john564
Re: Hamachi on Pi?
Fri Apr 26, 2013 3:50 pm
after you install it, you can use the hamachi IP address for SSH or OpenVPN
works fine
http://tryapi.wordpress.com/2013/03/31/ ... pberry-pi/
# The benefit of Hamachi, is you don’t need to do port forwarding on the router, once the
# raspberry PI is setup, you can just connect it to a friends router and SSH
# connect to the PI using the Hamachi IP address.
# Based upon this blog
# http://lifehacker.com/5978098/turn-a-ra ... ere-you-go
# use Soft-float Debian “wheezy”
# hamachi cannot install on standard Raspbian “wheezy”
# http://www.raspberrypi.org/downloads
# check latest hamachi at https://secure.logmein.com/labs/#HamachiforLinux
sudo apt-get update
sudo apt-get install --fix-missing lsb lsb-core
sudo wget https://secure.logmein.com/labs/logmein-hamachi_2.1.0.86-1_armel.deb
sudo dpkg -i logmein-hamachi_2.1.0.86-1_armel.deb
sudo hamachi login
sudo hamachi attach [your hamachi email address]
sudo hamachi set-nick [whatever nickname you make]
# check status
sudo hamachi
# TIP: I got error
# hamachi login
# Logging in .. failed, busy
# workaround
# /etc/init.d/logmein-hamachi stop
# /etc/init.d/logmein-hamachi start
