Mumble Server: Control Channel (TCP) High Latency issue
Posted: Sat Apr 20, 2013 9:21 am
by Magbed
Hi
Im running mumble-server on a raspberry pi on my LAN network which runs raspbian.
The voice channel (UDP) is working awesome with 1ms or so delay, but the Control Channel (TCP) has a really high latency as show in the picture below, as a result switching between channels take ages.
Could use some help. Thnx
http://s24.postimg.org/maq7cozlx/Contro ... _Issue.jpg
Re: Mumble Server: Control Channel (TCP) High Latency issue
Posted: Sat Apr 20, 2013 11:09 am
by Magbed
Found the issue.
SD wasnt fast enough for mumble SQLlite db
I just moved it to a ramdrive (used $mount -t tmpfs tmpfs /ramcache), and high latency was gone
Posted: Sun Apr 21, 2013 6:48 am
by Piminiuser
Thnx for your solution!
Posted: Wed Dec 18, 2013 11:54 am
by monnier
I have recently set up a mumble server on my raspberry pi but I get 10000+ ms on my control channel. (3ms on my voice channel even if I'm having trouble getting good sound quality)
I'm a total noob when handling linux.
Any idea that can help me? I have forwarded the correct port on my router.
Br Mikael Monnier
