Powerphil
Vpn wifi crash
Fri Apr 12, 2013 8:32 pm
I've upgraded my pi to wireless which was straightforward, but when I try and use the vpn (pptpd) connection over wifi, the raspberry pi crashes. When I revert to wired, everything works fine.
Any ideas
Powerphil
Re: Vpn wifi crash
Mon Apr 15, 2013 7:50 pm
Bump
SirLagz
Re: Vpn wifi crash
Tue Apr 16, 2013 1:17 am
Crashes as in Kernel Panic ?
Total Freeze ?
Do you have a screen connected to the Pi so you can see what it does when it crashes ?
Is the WiFi dongle plugged straight into the Pi or is it plugged into a powered hub ?
My Blog - http://www.sirlagz.net
Visit my blog for Tips, Tricks, Guides and More !
WiFi Issues ? Have a look at this post ! http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=44044
Powerphil
Re: Vpn wifi crash
Tue Apr 16, 2013 5:24 am
Dunno about kernel panic...how do I tell?
No display plugged in
Wifi is straight into pi
SirLagz
Re: Vpn wifi crash
Tue Apr 16, 2013 6:48 am
Plug a screen in so you can see what goes on when it crashes.
Goss1982
Re: Vpn wifi crash
Mon Apr 22, 2013 2:22 pm
Hi. Have you had any luck with this? I had the same issue months ago and decided to stick with it being hard wired in the end. Someone suggested it may be to do with the USB wifi adapter causing the crash due to incompatibility with this type of connection. I have no idea.
abiheiri
Contact: Website AOL
Re: Vpn wifi crash
Sat Feb 08, 2014 6:04 am
I'm also having this problem :?
